looking for some cam swap and heads characteristics...
Old Sep 20, 2003 | 12:05 AM
scoobysnax83's Avatar
The Z's full of power, but is awful in normal driving. I understand that until the PCM gets reprogrammed for the L.E. Heads and LT4 hotcam it is going to run a little odd. Here are a few symptoms. If you could just tell me if these are normal before a reprogram.
1st - rough idle
2nd- surging idle
3rd - surges under part throttle (not sure if it is part throttle hesitation but when floored there is no lack of power ).
4th - bad gas mileage
5th - HIGH Idle starts. Like 1800 to 2100rpm. Then quiets down in like 30 seconds to around 900rpm.
Thanks for the help. I think all this is normal when swapping in a cam and heads with out programming. I just need a little piece of mind.
Old Sep 20, 2003 | 01:01 AM
PoorMan's Avatar
Yeah, they all sound about right. I bet it feels like its going to die when in gear too huh? A tune will fix all that. No problem.
Jeff D.
Old Sep 20, 2003 | 04:55 AM
QCKZ28's Avatar
yep that sounds about normal for an untuned heads/cam car. mine was like that until i got pcmforless. now it starts like stock, idles (except for the lope) like stock, and the only cam surge i have is in OD about 45-50mph.
Jesse
Old Sep 20, 2003 | 05:40 AM
Thanks for the peace of mind fellas.
BTW: its an M6
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
chuyz28
Feb 19, 2015 12:50 AM
chuyz28
Jan 15, 2015 04:14 PM
chuyz28
Nov 25, 2014 11:14 PM
jmzlt1
Mar 13, 2003 07:26 AM
