What kind of Oil is best for LT1's
Old Sep 18, 2003 | 11:09 PM
96HealyZ28's Avatar
What kind of oil does everybody use in your LT1's, 10w 30, 20w 50? is 20w 50 to thick?
Old Sep 18, 2003 | 11:13 PM
LPE Z convt's Avatar
Royal purple
Old Sep 18, 2003 | 11:14 PM
AndyB's Avatar
The best oil is whatever gets changed on a regular basis. I just use whatever is on sale for the week
Old Sep 18, 2003 | 11:23 PM
95BlackTA's Avatar
Mobil 1 synthetic is jes dandy for me
Old Sep 18, 2003 | 11:34 PM
chasmanz28's Avatar
i run 10w30
Old Sep 19, 2003 | 12:00 AM
96ssz28#395's Avatar
Nothing but Amsoil 5w30 here. www.amsoil.com check them out.
Old Sep 19, 2003 | 01:25 AM
Compstall's Avatar
*CLEAN* oil is the best I ever used.
Old Sep 19, 2003 | 03:36 AM
5.0THIS's Avatar
I run 5w30 Mobil 1, but I have a relativly low mileage car and some often times very cold winter weather to deal with. Many people run 10w30, which is also just fine
Old Sep 19, 2003 | 04:24 AM
hvyss's Avatar
I use Castrol Syntec 10w40. Have changed every 2,000 miles due to hard driving and drag racing on juice. Just a peace of mind.
HVY SS
Old Sep 19, 2003 | 04:30 AM
Z-Scrilla's Avatar
Originally posted by chasmanz28
i run 10w30
Same here.
Old Sep 19, 2003 | 07:53 AM
1995ta's Avatar
I've always ran 5w30 Valvoline
Old Sep 19, 2003 | 07:57 AM
ishz28's Avatar
I usually run Mobile 1 Syn. 15w-50.
Old Sep 19, 2003 | 07:59 AM
LeftoverChinese's Avatar
http://web.camaross.com/forums/showt...hreadid=154214
Mobil1 0w40 this time
Old Sep 19, 2003 | 08:12 AM
stereomandan's Avatar
Another vote for Mobil 1 10W30 Synthetic. Walmart has these perfect sized 5 quart jugs of it now for around $18.
3 reasons
I never drive in very cold conditions(less than 30 degrees F)_
The higher viscosity gets me a little more cushioning on the internals and maybe slightly higher compression if things ever start to wear
It holds up well in our high temp engines
Dan
Old Sep 19, 2003 | 08:14 AM
Hyperspeed97z28's Avatar
I used Mobil 1 for about 40,000 miles then switched over to Max life 10w30 at 75k... No problems, Good oil...
