A horrible, horrible thing has happened, and im afraid its as bad as it sounds
Ok lemme try to catch my breath here, about 3 days ago my car started hesisating, and the idle was surging when hot, well it didnt really go away, or get worse until today. I went to pick up a friend from school, and on the way back my car is hesitating really bad and the temp is steady rising, well i pull into my driveway just as it reaces the red. I shut the engine off, and look at the car, i look under it and notice a little bit of coolant dripping, well i think maybe the coolant has been dripping on the optispark and making my car mess up, well i crank the car up, let it run, and notice the temp rises a bit, then i hit the fans, and it was going back down, so i turn off the car, check some fluids again, and i go to crank it, and THE WORST SOUND IVE EVER HEARD IN MY LIFE. It was an awful grinding sound that could have made the strongest man cry........im not too educated about what this could be, but im thinkin nothing good can come of this, it has to be very serious.....spun bearing, blown head gasket wtf happened???
If the waterpump went south and locked up you could be grinding the teeth off the drive gears for the pump....you need to see if the coolant is coming from the weep hole and replace the pump now if its bad.
Pop the hood, get someone to have their head by ( NOT AGAISNT ) the engine, crank it real quick, and have them determine where its from ... Im guessing that the head gasket went ... In which case id change the oil and see if its milky, if its ok , then id look elsewhere for the problem, and if the oil is milky colored, for the love of god DONT ruin a perfect shortblock ... Dont run it again untill you fix the leak , AND FLUSH it with some cheap .99$ oil
Originally posted by notstock4long
Are you sure the car was off when you tried to start it again?
That does make a very bad sound. But did you have any coolant left, or was it all gone?
i was gonna ask the same thing, because that sound is just horrid
