Clear corner light install...please help FAST
Old Sep 17, 2003 | 07:03 PM
AxeGrinder30thZ's Avatar
Ok, I've got the splashguard off and I've got the stock light unbolted but I can't get the big main bulb out. The part that holds the bulb down in the light has the word "Lock" with an arrow on it but I can't get it off...how do I get the bulb out? Thanks.
Old Sep 17, 2003 | 07:24 PM
brandboZ28's Avatar
If I remember correctly, it takes a little muscle to get it turned. Just mash the lock and give it a good turn to the left(I think) and it should pull straight out. I had the same problem, it just didnt want to come out. Look at the clear corners and get an idea of how the light twists in.
Old Sep 17, 2003 | 08:18 PM
There is an outer ring on the socket. You squeeze part of it and turn the socket ¼ turn.
Old Sep 17, 2003 | 09:29 PM
Thanks guys. I got the lights installed. The problem was I didn't want to give it too much muscle, cause I thought I was going to break it, but it went ok. I just did what you said and went for it. They ended up looking good. I was skeptical when I bought them cause I have never seen these on a white camaro, much less a 30th anni with orange stripes. If anyone is interested in seeing how they look, let me know, and I'll post some pics. Thanks again fellas.
Old Sep 17, 2003 | 10:04 PM
brandboZ28's Avatar
Go ahead and post them up and show off your hard work
97FormulaWS-6
Sep 11, 2002 11:57 AM
AW/whiteZ-28
Aug 27, 2002 12:53 AM
AW/whiteZ-28
Aug 22, 2002 11:53 PM
97FormulaWS-6
Aug 5, 2002 05:15 AM
AW/whiteZ-28
Jul 25, 2002 04:09 PM
