Cam Removal handle
Old Sep 18, 2003 | 11:19 AM
rocmemphis's Avatar
Cam Removal handle
Anyone know where to get one that will work with LT1 camshafts?
Old Sep 18, 2003 | 04:56 PM
llafro's Avatar
Go to a hardware store and buy a couple of long bolts with the right thread pattern. All you need is something to hold onto when you pull the cam out. Put the bolts into the end of the cam and wrap a rag around them to make it easier to hold onto.
BRAD
Old Sep 18, 2003 | 05:01 PM
97bowtie's Avatar
You can just use the bolts that hold the cam gear on. Thread the three bolts in, just enough for them to hold (couple threads) and slide the cam out.
Old Sep 18, 2003 | 05:04 PM
BOWTYDE's Avatar
Like they said use those bolts, you'll need 3 - 5/16" bolts - 3" long
Old Sep 18, 2003 | 05:18 PM
94formulabz's Avatar
I got 3 long bolt from the hardware store as mentioned above. Or you could remove the timing gear, remove the retainterplate, reinstall the timing gear and remove it with that. Even cheaper than buying 3 bolts!
-brent
Old Sep 18, 2003 | 05:19 PM
97bowtie's Avatar
The three short bolts that hold the timing gear on are plenty to remove the cam. You just have to get it far enough out to get your hands on the first journal.
Old Sep 18, 2003 | 05:21 PM
Re: Cam Removal handle
It would be one that would work with any SBC cam. Auto parts store or speed shop.
Old Sep 19, 2003 | 08:27 PM
magnumv8's Avatar
Just use the 3 5/16 x 3 inch bolts, they should cost less than $1.00. If your removing the cam with the motor in the car, just remove the bolts after you have the cam about half out otherwise the bolts will hit the hood latch.
Old Sep 19, 2003 | 11:56 PM
QCKZ28's Avatar
i used a 6" 3/8 drive extension, i just put it into the end of the cam and used it as a lever to guide it through the bearings....
canbaufo
May 25, 2015 12:01 PM
StansZ28
Feb 19, 2015 07:39 AM
Cam's maro
Jan 30, 2015 09:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
