where do i find this type of compressor ???
Old Sep 18, 2003 | 03:11 PM
94heritageZ's Avatar
Question where do i find this type of compressor ???
Where do i find this type of valve sprong compressor ? i need
this one because it has the arms that hold the shim in place
and it doesnt let the spring slip out . Thanks
http://www.streetillusionsracing.com/RR/Image018.jpg
Old Sep 18, 2003 | 03:45 PM
Don 97 SS's Avatar
That looks like a K&D spring compressor. I've used that kind before. I used that kind once to install springs on my LT1 w/engine in the car. I wasn't that impressed with it. It was o.k. but nothing to write home about. It doesn't work well with a single spring and a dampner and really won't work with a dual spring!
The one I now own (after using three different types) is the Moroso stud mount. Moroso
It works well with dual springs and reaches ALL cylinders! I love it. I think it is much easier than that K&D model.
I got the Moroso at Summit, if you want the K&D you can probably buy it at NAPA. I think I saw them there.
Old Sep 18, 2003 | 03:55 PM
nateh's Avatar
Ditto on Don's recommendation. That compressor will have a terrible time with dual springs. The Moroso unit is good, and there is a clone of the Moroso part made by Big End that costs a lot less. That's what I did my springs with. You have to dissasemble it to work on the back springs, but it does a good job.
Old Sep 18, 2003 | 04:22 PM
rocmemphis's Avatar
Worst compressor ever made!!!
Buy a moroso or proform stud mount compressor.
Old Sep 18, 2003 | 04:39 PM
Bah! Worked fine for my spring swap with flat inner springs. I agree that it won't work for dual spring with a round inner.
I did try the Proform and it was a POS. I assume the Moroso is a better unit.
The KD tools are available at most auto parts store.
Old Sep 18, 2003 | 05:13 PM
94formulabz's Avatar
Bah is right! I used the even cheaper lislie (sp) one from pep boys and it worked fine. Didn't even have those inner ears to keep it centered on the retainer. i just took two minutes to grind a lil angle onto the feet and it hasn't slipped since. I'm sure there are better ones, but it's not like i'm changing springs every week to justify spending a lot more money on something only slightly more user friendly when what i got works.
warmeck
Mar 16, 2015 07:02 AM
99TransAmWS6
Feb 12, 2015 07:23 PM
alphaauto
Feb 5, 2015 05:25 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
