Rear Brake options?
Old Sep 17, 2003 | 10:45 PM
Z-OwNEr's Avatar
Rear Brake options?
Here are the lovely pics http://www.azfba.com/messageboard/attachments/Brake.jpg
http://www.azfba.com/messageboard/at...nts/Brake2.jpg
I figure I probably need to just replace the caliper, rotor and pads...should I replace the caliper on the other side too or just pad and rotor? Where is the best place to pick up these parts?
Old Sep 18, 2003 | 01:57 PM
Z-OwNEr's Avatar
no one?
Old Sep 18, 2003 | 02:18 PM
atljar's Avatar
EEK that looks nasty.
Rotor and pads on both sides, and i would go over both calipers very carefully, you may be able to reuse that one (did it just run out of pad? or was it sticking etc.) You can tell a lot by comparing one side to the other on pad wear etc.
I like autozone pads, nothing high performance, but they will replace them for free for lifetime of your car
Old Sep 18, 2003 | 08:16 PM
Z-OwNEr's Avatar
How exactly do I go about checking over the caliper thoroughly to ensure it's in good operating order?
Old Sep 18, 2003 | 09:27 PM
dynomight's Avatar
An option... www.aerospacecomponents.com
Old Sep 18, 2003 | 10:17 PM
atljar's Avatar
Check to make sure the slide pins slide smoothly, and dont wobble. Then as long as the piston hasnt been ground into by the rotor, i would say you are safe.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
ddr698
Jan 9, 2015 10:05 AM
rockync7
Jan 1, 2015 05:10 AM
Jazsun
Dec 29, 2014 12:14 PM
