Pulsing Noise Coming From The Engine???***
Old Sep 20, 2003 | 04:14 AM
96a4z28's Avatar
well today i took off the rubber intake thingy that connects to the throttle body so i can spray the throttle body with some cleaner for it..then i put everything back. and now at idle u can hear a slight ticking noise coming from the engine compartment, almost like a pulse or arching or somethin.i tried to trace it but couldnt find where it was comin from. .very weird. and sometimes it causes the idle to get alittle rougher. but the car runs fine and has power. could it be one of the TOO many sensors near the engine that came aloose when i cleaned the tb???i just dont want to keep driving and this gets worse or turns into somethin worse. anyone who knows of this please drop some knowledge.. apreciate it!!!
Old Sep 20, 2003 | 06:16 AM
scoobysnax83's Avatar
you'll have to be a little more specific. I know it may be hard but it could be anything. Are you sure the intake is on correctly (rub your finger around the bottom). Try to describe it a bit more. Is it coming from one side of the engine? Good Luck.
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
jayblev95
Dec 1, 2014 06:55 AM
squarehead
Nov 21, 2014 08:02 PM
StngStlkr
Sep 6, 2002 05:47 PM
