BFG-DRs with stock 10-bolt
Old Sep 19, 2003 | 11:14 AM
Got-LT1?'s Avatar
Hey i was thinking about running bfg drags for the occasional 1/4 mile run on my camaro, and i was wondering how bad they would be on the stock drive line. Will my clutch and 10-bolt last very long with tires that sticky? my mods are below with the addition of some jet hot Lts which are going to be installed soon...
Old Sep 19, 2003 | 12:08 PM
FacelessZ's Avatar
addition of a TA girdle wouldn't hurt at all...
Old Sep 19, 2003 | 12:33 PM
Compstall's Avatar
I've been using mine for the last 3 years that way, no problems. Of course I can't guarantee YOURS will last that long, some guys have had issues early in the game. I think I might have gotten a "good" one.
Old Sep 19, 2003 | 12:37 PM
BradZ28's Avatar
Could blow it on the first pass, may last well into the 11's. Just a crap shoot. I would think about a way to get the car home if it goes at the track.
Brad
Old Sep 19, 2003 | 02:19 PM
WheelmanZ28's Avatar
Are u guys serious?
Drag Radials are perfectly fine for a stock rear end. U don't need a girdle, better axles, etc.
I have seen guys on a pretty much stock LT1 running slicks and cutting 1.6 60' foots and their rear ends are just fine. A friend of mine has BFG DRs on his Z and he sumpts the clutch @ 4k RPMs with no problems. Drag Radial won't dead hook as much as a slick, so i HIGHLY doubt u will have any rear end problems.
Old Sep 19, 2003 | 02:54 PM
BradZ28's Avatar
Last week a bone stock 94 Z/28 popped the rear on street tires at Great Lakes Dragway. I think he did have a K&N but that's it......maybe he didn't have any gear lube in there?
Old Sep 19, 2003 | 03:53 PM
TenaciousZ's Avatar
maybe he's been abusing his car a little too much? just last wednesday a built ls1 threw a driveshaft. it happens!
Old Sep 19, 2003 | 04:02 PM
TedH's Avatar
You can break stuff at any point.
Realistically, a few jaunts down the 1/4 mile should be fine.
If you do what I did and start racing every weekend you will have problems. I rebuilt the stock rear twice prior to getting a 12 bolt. I found the stock rear was basically good for about 400 passes, or one season for me with running two classes at two tracks.
It is the launch shock that really kills parts. A good launch on drag radials for me with minimal mods back then would yield 1.8's and that was sufficient to break parts over time.
Got-LT1?'s Avatar
Hey thanks for the input guys, I guess I will run them and take the risk Im not really sure what a TA gurdle is but where can i find them?
Old Sep 19, 2003 | 04:39 PM
anaik's Avatar
Here's some info on the girdle.
http://www.off-road.com/chevy/review...iffcovers.html
Check with the boards advertisers to buy one.
Old Sep 19, 2003 | 05:02 PM
CamaroBoy96Z28's Avatar
I run my BFGs on my stock rear with no problems. I do have a SPEC stage 2 sitting in my room ready to go on when the stocker fails/when I get my 12-bolt next year. On the other hand, my friend's 02 Z28 broke his rear on BFG drags but he had 4.10s which is most likely why.
Old Sep 19, 2003 | 06:18 PM
FastZinTennessee's Avatar
I've been fine with mine
Old Sep 19, 2003 | 06:26 PM
RamAir95TA's Avatar
I have dozens of 60's in the 1.8 range, and a handful of peg-legged 1.7 60's, and the stock rear is holding nicely. Then again, I have a MAC girldle, welded axle tubes and an Eaton carrier.
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
TitoPR221
Jan 29, 2015 08:00 PM
super83Z
Jul 11, 2002 10:16 PM
