Need power door lock help.... (wiring)
Old Sep 19, 2003 | 12:56 PM
madwolf's Avatar
Arrow Need power door lock help.... (wiring)
I had a problem with power door locks not working a while ago. I found out that some wires were cut and wired to an alarm that was not connected. So I removed the alarm wires and reconnected the original wires. This resulted in the following condition:
ONLY driver side DL can be controlled with both passenger and driver side switches.
After some further examining, I found that all the wires leading to the passenger side are fine, except the TAN wire that goes from the driver side to the passenger side actuator. I found that the wire is disconnected right near the door to interior pass. I could not find the other end, however, I jumped this wire to the interior side of it and I still don't get continuity on the actuator side. What can I do? I've pretty much taken all the interior appart and I can't figure out what's wrong. Any easy way to fix this besides running a new wire? (PITA)
Thanks!
Old Sep 3, 2007 | 04:43 PM
GMH94Z28's Avatar
What did you ever do about the tan wire? I used to have alarm in my car and pulled it out but i have a tan wire that isnt connected to anything. Thanks
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
phatbasslines
Jan 13, 2015 05:03 PM
siguy
Nov 27, 2014 10:07 AM
