High rpm vibration
Old Sep 20, 2003 | 12:24 AM
SS Mark's Avatar
High rpm vibration
Lately at above about 4k i have been getting a vibration throughout the whole car, my first guess was the driveshaft. But if anyone has any other ideas or had this happen to them please let me know so I can get it taken care of before I go to the track.
-Mark
Old Oct 19, 2003 | 02:33 AM
pvkn1ght's Avatar
sounds like me - im with you man
ttt
brian
Old Oct 19, 2003 | 09:12 AM
Hyperspeed97z28's Avatar
I get it through what feels like the right rear wheel the most, But I got that constant viberation too... What the hell could it be, Is it really only the driveshaft?
Old Oct 19, 2003 | 09:20 AM
stonecoldz's Avatar
i've been getting the same thing also
Old Oct 19, 2003 | 11:56 AM
97f1z28's Avatar
i'm with you guys. This is a new problem for me. I recently had the trans rebuilt and since then I have the vibration. It is only there if i have it in D and am around 40-50 MPH. Or if I am in any gear and floor it. I have a deenys HD alum. Driveshaft and a new B&M 2500 holeshot converter.
So any ideas whats causing this?
Old Oct 19, 2003 | 01:22 PM
unvc92camarors's Avatar
maybe a wheel balance and alignment will cure it
just a thought
Old Oct 20, 2003 | 10:42 AM
SS Mark's Avatar
Ended up being a bad plug wire and it was misfiring more noticeably at higher rpm's. Check your wires those of you that are having problems.
Old Oct 20, 2003 | 10:56 AM
i387's Avatar
High RPM vibration = before the transmission
Unbalanced flywheel, engine missing, etc.
High MPH vibration = after the transmission
Unbalanced driveshaft, tires, etc.
Old Oct 20, 2003 | 10:02 PM
aaaah, i read it wrong
my fault
Old Oct 26, 2003 | 08:53 PM
pvkn1ght's Avatar
... how about a high rpm/mph vibration?
1, 2, 3rd gears are fine. 4th & 5th shake the whole car horribly through what feels like the dash/centerconsole area, not the steering wheel. Or you can say the car shakes/vibrates in 5, 6th gears above ~85mph
> what are the chances it's the driveshaft VS tranny mount?
I do not notice any thunking when driving or shaking at lower rpms/speeds. *sigh* yes i've had my tires balanced, rotated, and wheels aligned
Old Oct 26, 2003 | 08:57 PM
RedPhenx's Avatar
high rpm... could be bad flywheel?
Old Oct 27, 2003 | 07:58 AM
IslandZ's Avatar
Or bad harmonic balancer like mine. Had a power steering pump fail and leak oil on my balancer, now it is starting to separate from the pulley. new one on order though.
Apr 16, 2015 09:57 AM
BigWil
Mar 29, 2015 12:24 PM
Rde Bandit
Mar 21, 2015 10:17 PM
mattszm6
Dec 14, 2014 07:09 AM
PhantomTA
Aug 17, 2002 12:19 AM
