1/4 mile times inside ?
Old Sep 19, 2003 | 08:21 PM
robb4964's Avatar
Went to the track today with my fresh 4:10 install , and My best 60ft time was a 2.458 , The car cut out thirty feet from the 1/4 mile line , every single run . the fuel shut down . I ran it many times and well before I could get to the end of the track it cut out . I still managed to run a 14.1 @94mph . I ran a 14.2 w/a set of 3:23's @ 100mph with a slipping clutch and only one wheel working w/a 2.4 60ft then also with good traction and no fuel cutout , what do you think my times would be ? any suggestions ?
Old Sep 19, 2003 | 10:00 PM
chesee48's Avatar
for sure. get some drag radials and heat them up and you'll cut better 60ft times and hit high 13's for sure.
good luck
Old Sep 19, 2003 | 10:04 PM
robb4964's Avatar
good luck
I know that , but my fuel is cutting off cause of a computer prob , 30 feet before I get to the 1/4 . So i was wondering , if it would hit the low to mid 13's . It would have hit 13's with the 3:23's had i had traction .
Old Sep 19, 2003 | 10:09 PM
robb4964's Avatar
BTW thanks for wishing me good luck im sure it will hit a 13.5 ,I was just wondering what everyone else though . the thing was roasting straight thrue 1st-3rd and grabbed 4th , when the fuel cut out it would not return functionability until after i coasted pass the tracks 1/4 . It cuts out at 3000 rpm's in 6th and at 5400 in 4th , when it does it wont go into 5th when it does it . Im going to send the PCM out and see if it helps to get reprogrammed . ill post my new times if i ever get them
D1SC383LT4
Jan 1, 2016 01:56 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
capebuf
Jan 13, 2015 07:22 PM
Queens94z28
Dec 20, 2014 09:11 PM
