a little too much oil
Old Sep 18, 2003 | 11:27 AM
rage366's Avatar
well, i was putting some oil in the car, and i accidentally put in the entire quart, instead of maybe 1/2 to 2/3's of it.
i checked the dipstick, and it's showing about 1/8th of an inch past the LAST little hole.
i cant afford any leaks, so any suggestions? will that much of an overfill cause any damage?
thanks.
Old Sep 18, 2003 | 11:29 AM
Robert95z's Avatar
hmm drain some out?
Old Sep 18, 2003 | 11:31 AM
94formulabz's Avatar
I don't think it's leaks you have to worry about. The problem with overfilling is the oil becomeing aireated (sp) when the crank whips it into a frappe. Doesn't sound like your overfilled it that much, but you could just drain a lil to be on the safe side.
-brent
Old Sep 18, 2003 | 11:32 AM
grygst76's Avatar
that all depends. if it is a pubic hair over no. If it's more towards 1/4 inch no. if it's half inch yes what it does is put strain on the crank and then the crank will start to beat or froth the extra oil and aerate it causing you pump to pick up air instead of ol which ruins the pump and then you get tiny bubbles running thru the bearings, not very pretty.
Old Sep 18, 2003 | 06:49 PM
pearlpurple's Avatar
if you're only 1/8" of an inch over filled don't sweat it that isn't going to hurt a thing.
RX Speed Works
Jul 24, 2015 02:25 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
