What needs to be done to put a 3.875 crank in?
Old Sep 18, 2003 | 06:21 PM
onebad96T/A's Avatar
Does the block have to be cut to fit a 3.875 stroker crank?
My plans are building a 396ci
Old Sep 18, 2003 | 07:58 PM
96z's Avatar
96z
You'll have to clearence the block, and most likely get a new oil pan. My rods had to be slightly clearanced also.
Old Sep 18, 2003 | 08:21 PM
I allready have a set of 6" Scat rods that should work fine, what are some of the choices of cranks that makes a 3.875 stroke and 1 piece rear main seal?
Lunati
Scat
Callies
Eagle
Cola, etc..
I planning on spending around 700 or so on a good forged crank, just which one?
Also is anyone running a 4.00 stroke crank in a LT1 or 4 block?
Old Sep 18, 2003 | 09:43 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Similar question. How much clearancing would have to be done to a 2 bolt 400 block to put in the 3.875 crank?
Old Sep 18, 2003 | 10:33 PM
jimlab's Avatar
Re: What needs to be done to put a 3.875 crank in?
Yep, by about this much.
http://home.gci.net/~jimlab/images/B...d/PB160063.jpg
http://home.gci.net/~jimlab/images/B...d/PB160044.jpg
Old Sep 18, 2003 | 10:35 PM
jimlab's Avatar
Not much. The stock stroke is 3.75" in a 400.
kmook's Avatar
Advanced Tech Moderator
Moving to LT1 Tech.
Thanks.
Old Sep 18, 2003 | 10:40 PM
Re: Re: What needs to be done to put a 3.875 crank in?
Sweet pics.
Old Sep 18, 2003 | 11:31 PM
DarthIROC's Avatar
Yeah I was originally going to do a 4.0" in teh 400 to make an small block 427, but everyone told me I shouldnd do it with an OEM block. So I thought I would comprimise, and go in between teh stock stroke and the 4"
Old Sep 19, 2003 | 02:35 AM
jimlab's Avatar
Well, a 0.030" overbore and a 3.875" crankshaft would take you to 420 CID without much effort, probably.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
pimpss96
Feb 12, 2015 01:28 PM
cyteone
Feb 7, 2015 06:04 PM
1LEThumper
Jul 14, 2003 12:45 PM
