Hard to start, everyone once in a while, won't start?
Old Sep 20, 2003 | 12:05 AM
raxxus's Avatar
Hey guys!
My car take 4-5 seconds to start when its cold, usually. But, everyone once in a while, it just sits there and will tick when I try to turn her over. After acouple trys, it will all of a sudden start up fine. I checked the batt. connection, and it is solid. Cleaned it too! Anyone have any ideas?! Thanks guys!
Old Sep 20, 2003 | 03:53 AM
daveyd94z's Avatar
Sounds like you need a new battery.
Old Sep 21, 2003 | 12:26 PM
raxxus's Avatar
Unhappy hmm
Alright! I went to AZ and the guy there checked out the bat.. and said it was good! any other ideas?
Old Sep 21, 2003 | 01:09 PM
grossesexy's Avatar
you might want to check out the condition of your wiring and ignition components. seems kind of obvious but you never know.
Old Sep 21, 2003 | 02:07 PM
CoUnTryMuZiCZ28's Avatar
Check your connections on your starter... Buy some electronic cleaner and just stick your head underneath the car and spray away.. hose it off and you should see a difference.. Just my .02.. Let me know how it works if you decide to do it.. I did it on mine and it fires right up..
Old Sep 21, 2003 | 02:25 PM
killerkelly95's Avatar
ok! something is wrong there! maybe you need a new battery or check the ingnition or something. hope i helped u some let me know what happens
Old Sep 21, 2003 | 02:34 PM
NOMAD's Avatar
Cool
If your car clicks, but never turns over sometimes, your getting power to the starter, just not enough.
Sometimes my car does this if I don't have the cables tight enough. Make sure your getting them on straight and tight. Make sure the connections are clean and rust/corrosion free. When you get them on, try to move the actual connector back and forth on the battery to make sure the connection is tight. If everything is tight and connection is good, try a new or proven battery. I don't trust these stupid autozone battery places. I took one there one time and they denounced anything was wrong with the battery. I went home and tried to pull the battery out, realizing the shop that worked on my wifes car had tightened it up so much it actually pulled the connector out of the battery casing and leaked all the battery acid and water out. Yep, battery tested fine
-Shannon
Old Sep 21, 2003 | 06:15 PM
ThotYouKnew's Avatar
my car was doin the same thing...wouldnt start like 2 times last winter and then it was fine through the winter and then as soon as it got just a tid bit cold here in ohio it started clickin again and wouldnt start and then i noticed some acid in the garage and then i noticed acid runnin down the side of it...it was still showing a good charge but i said the h*ll with it and just replaced it...now it starts up no questions asked...never struggles...oh and before it was replaced i cleaned up the connections with some water/baking soda....just keep applying until the fizzing stops....good luck
eazyZ
Mar 1, 2015 07:12 AM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
