Ran slower with PCM For Less tune...help with tune (madwolf?)
Old Sep 18, 2003 | 07:48 PM
97bowtie's Avatar
The conditions were better last night than when I was trapping near 111 mph a few months ago. The only difference between the two times is a new Walbro 255 fuel pump and a PCMforless tune.
Before I replaced the fuel pump, I was seeing 30 psi @ idle and 25-28 psi at WOT above 4500 RPM. With the new pump, the fuel pressure is right where it should be...42-45 @ idle and around 40-43 psi at WOT.
I think the tune may have a little too much timing in it up top and may be running a little lean.
Can some of you guys take a look at this file and tell me what you think?
The best ET last night was 12.7 @ 109.8. The track prep was non-existent and I couldn't get the car to hook up at all, but I would think with the tune and better conditions the car would go 112ish. I appreciate any input.
http://www.public.asu.edu/~dbump/danielcc305.bin
Thanks.
Old Sep 18, 2003 | 08:00 PM
madwolf's Avatar
The tune may be a little lean (and I would also try removing a degree from WOT 2800-5000 timing) and you may be getting some knock retard, but I'd email Bryan directly and ask him for an opinion, rather than post the file on the board.
Another thought would be that if you do not have an adjustable fuel pressure regulator, the pump may be pumping fuel at a higher pressure (seen that before) which would make the injectors flow more than the PCM knows about. Check your fuel pressure and see where it's at.
Old Sep 18, 2003 | 08:05 PM
97bowtie's Avatar
Originally posted by madwolf
The tune may be a little lean (and I would also try removing a degree from WOT 4000+ timing) and may cause some knock retard, but I'd email Bryan directly and ask him for an opinion, rather than post the file on the board.
Thanks for replying. I had him tune the pcm mainly for the obd1 conversion and to have a baseline tune. I have Tunercat and a laptop...I'm just waiting on a cable. I plan on doing the rest of the tuning myself so I just wanted some input from some of the more knowledgeable tuners on the board.
As far as fuel pressure goes:
Before I replaced the fuel pump, I was seeing 30 psi @ idle and 25-28 psi at WOT above 4500 RPM (car was scary lean on the dyno). With the new pump, the fuel pressure is right where it should be...42-45 @ idle and around 40-43 psi at WOT.
Old Sep 18, 2003 | 08:06 PM
madwolf's Avatar
OK... fuel pressure sounds right then. Hook up your laptop and check for knock retard. That's most likely what's slowing you down.
Old Sep 18, 2003 | 08:12 PM
97bowtie's Avatar
Das what I figured. Thanks.
Old Sep 18, 2003 | 08:32 PM
96speed's Avatar
Ion, I think you're a little backwards . With the stock regulator, the FP should be ~43.5 regardless of what pressure the pump is supplying - unless its lower than 43.5 ofcourse .
Ryan
Old Sep 18, 2003 | 08:34 PM
madwolf's Avatar
Ryan
No clue. I've seen myself 50 PSI on a car with a stock regulator and a Walbro 255 Hi Pressure unit. Maybe the regulator was bad...
Old Sep 18, 2003 | 08:36 PM
S.J.S.'s Avatar
What do you do about the knock retard?
Old Sep 18, 2003 | 08:37 PM
madwolf's Avatar
If real and programming induced, correct the air to fuel ratio and/or timing.
Old Sep 18, 2003 | 08:42 PM
96speed's Avatar
My car goes anywhwere from 40 to 50psi with the Walbro, but its generally understood that that is normal. That is the whole point of a regulator. Now...if its pretty far off, your regulator is bunk :-).
Ryan
Old Sep 18, 2003 | 08:49 PM
madwolf's Avatar
50 PSI is a 15% increase over the stock 43.5... AFAIK, the normal range for a PCM to compensate is ~10% and that at part throttle. At WOT, you will definetely see the difference in pressure.
But this is already O/T.... so feel free to PM me if you want to argue more.
Old Sep 18, 2003 | 08:55 PM
allmotorta's Avatar
Exactly what I'm seeing right now. 52 psi, stock regulator, walbro gss340 high pressure pump.
DirtyDaveW
Dec 1, 2016 05:37 PM
DSMKilla
May 26, 2015 10:10 PM
CARiD
Jan 27, 2015 06:27 AM
smacz28
Aug 6, 2002 01:51 PM
jd13
Jul 30, 2002 10:35 AM
