Throtle body cleaning - cold start
Old Sep 20, 2003 | 10:06 AM
ASIM's Avatar
Hey Guys:
I noticed that my revs weren't coming down as quickly when I came to a stop and I had a generally rougher idile than normal. I bought some throtle body cleaner. The can says to spay it into the TB while the car is on. I couldn't do that cause the car wouldn't start with intake elbow and sensors disconnected. So I just sprayed the butterfly and linkage and cleaned the area with a tooth brush.
I have since noticed that the idile is smoother, as is throtle response, but at cold starts the car wants to stall. It starts fine, but then starts to drop to 6/700 RPM. I'll gas it to bring it back, but then it will fall back to that same level. Once it warms up it's fine, and this did not happen at all before the TB cleaning last week.
Any ideas?
Asim
Old Sep 20, 2003 | 11:05 AM
PoorMan's Avatar
The IAC needs to be taken out and cleaned. You most likely had some of the carbon run down the channel from the Throttle body to the IAC. The channel is small. I would remove the throttle body take off the IAC and the lower casing of the throttle body and clean all that out. You will need a new lower throttle body gasket btw. I would also check the IAT sensor with an ohm meter sense you say its fine when its warmed up. I think Shoebox has the resistance measurements on his site.
Jeff D.
Old Sep 22, 2003 | 10:45 AM
ASIM's Avatar
Great. Just one question: What is a IAC? and how will I know when I found it?
Asim
Old Sep 22, 2003 | 10:55 AM
S.J.S.'s Avatar
You cant miss it. It's torxed to the bottom of the TB.
http://csce.uark.edu/~jgbertr/rb/iac3.jpg
Old Sep 22, 2003 | 11:46 AM
showtime89's Avatar
Idle Air Control
Old Sep 22, 2003 | 11:55 AM
predator's Avatar
if you unplug the maf sensor it will start up
Old Sep 22, 2003 | 12:01 PM
z28marine's Avatar
just gently brush it witha toothbrush, i used a needle to scratch off any hard carbon deposits...car ran alot better afterwards
Gtpguy
Jan 26, 2015 04:50 PM
squarehead
Jan 15, 2015 07:02 PM
Britbilly
Jan 7, 2015 08:49 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
