Rebuild questions
Old Sep 19, 2003 | 01:15 PM
FireAm94's Avatar
Question Rebuild questions
I purchased a 355 that had 3k miles on it. It has a forged crank and stock pm rods with arp bolts and trw forged stock replacement pistons. I will be installing SRP forged pistons and Eagle H beam rods for insurance with the bottle. The rotating assembly was balanced....I assume the new rods and pistons will be able to be balanced with the prebalanced crank...correct? Also when the rotating assembly is balanced will the flywheel or anything else be a problem? Will new bearings be necessary with 3k miles on it? Can the cylinders just be honed and use a standard size 355 piston or does it have to be bored.
Joe
Old Sep 20, 2003 | 11:14 AM
FireAm94's Avatar
TTT If you don't know all.....then answer what you know please
Thanx
Joe
Noenav
Mar 1, 2019 07:38 AM
Sergio
Jan 27, 2016 04:27 PM
armedtrigger
Feb 24, 2015 08:30 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
