LT4 Knock Sensor
Old Sep 18, 2003 | 12:42 AM
S.J.S.'s Avatar
LT4 Knock Sensor
If I got a PCM for my car do I still need the knock sensor?
Old Sep 18, 2003 | 01:08 AM
ZMAN Z28's Avatar
your question is vague.
do you mean if you got your computer reprogrammed, would you need a LT-4 knock modual. You can have your knock sensor de-sensatized in your computer if you have someone reprogram it. But I would not recommend dleting it.
ZMAN
Old Sep 18, 2003 | 01:17 AM
S.J.S.'s Avatar
Sorry....I know everyone is recommends the LT4 Knock Module. Someone mentioned that because I had the OBD1 conversion from PCM forless I would not need it. Is that correct?
Old Sep 18, 2003 | 07:45 AM
S.J.S.'s Avatar
ttt
Old Sep 18, 2003 | 07:59 AM
Are you talking about sensor or module?
You always need a sensor and there is not an "LT4" knock sensor. Converting to OBD-I has no bearing on what module you might want.
Old Sep 18, 2003 | 10:50 AM
S.J.S.'s Avatar
So shoe....I still need the LT4 knock module?????
Old Sep 18, 2003 | 11:14 AM
madwolf's Avatar
An LT4 Knock Sensor is the same thing as a 96-97 LT1 Knock Sensor. You're talking about the knock module which is located in the PCM.
As for whether you need it or not, it's not a necessity regardless if you had a 94-95 or a 96-97 car. Some people have seen some less knock retard with them, but if you're not getting any knock retard at all, you don't need one.
Old Sep 22, 2003 | 11:22 AM
S.J.S.'s Avatar
So I should just wait and see then? Will it throw a code is I do get some knock?
Old Sep 22, 2003 | 11:31 AM
To add to the confusion...
When you switch from OBD-II to OBD-I, you need to replace the high impedance (96/97) knock sensor with a low impedance (93-95) knock sensor.
Old Sep 22, 2003 | 11:53 AM
S.J.S.'s Avatar
You gotta be kiddin me Injun.......geeze why doesnt it say that on the PCMforless site? What next? Always something.
mightymouse383
Jul 20, 2016 07:34 AM
4586
Mar 18, 2015 06:31 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
dreamer1q
Aug 20, 2002 11:19 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
