clogged pvc valve?
Old Sep 17, 2003 | 05:29 PM
FacelessZ's Avatar
clogged pvc valve?
I was told that I have a clogged pvc valve...what could this be causing? How much is a fix?
Thanks!
Old Sep 17, 2003 | 05:31 PM
RamAir95TA's Avatar
Pull out the PCV valve (it's on the driver side of the intake manifold in a large rubber grommet) and shake it. If it rattles, it's fine. If it doesn't a replacement is less than $5.00 at any parts store.
Old Sep 17, 2003 | 05:36 PM
gb95zconv's Avatar
Re: clogged pvc valve?
Thanks!
If it is clogged it can cause major problem with pressure biuld up and oil being forced out of the engine......like was said erlier its easy to check and cheap to replace
Old Sep 17, 2003 | 05:41 PM
FacelessZ's Avatar
thanks guys
Old Sep 17, 2003 | 06:11 PM
anaik's Avatar
Here's a picture of it.
http://csce.uark.edu/~jgbertr/rb/pcv.jpg
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
