View Full Version : LT1 Based Engine Tech
- nitto
- Shorties or long tubes better on a stock car?
- 98+Console and ASR button
- cc305 with stock heads
- Cam Install Walkthroughs
- Does anyone know if cast heads are in demand
- Tranny probs please heeeellllllppp!!!!
- Gonna install a shift light or tach/shift combo.....
- Anyone Know Inj Fred's Email address??
- Help me pick my next suspension mod!
- Anyone have a problem after they installed a Walbro fp w/o the bucket?
- Drag wheel and tire ?
- Uh Oh!
- shortblocks?
- Lou's short stick?
- Guess my HP/ET!!
- . MSD Ignition Multiple Spark Descharge Box with Rev Limiter
- anyone run a patc "raptor" converter?
- torque specs and threadlocker on rr stud bolts please
- I think im in trouble!
- Anyone install A/F gauge
- How long untill Gas goes bad!?
- What now?
- Is there a problem with my heater core?
- what to do??
- just recieved slp shorties? wht next
- SLP 2OTL sound clips
- M6 Swap?
- After market Throttle Body
- Finally installed CC306
- connecting rods...
- Fuel Injector Size
- 335/35/17 BFG's on 17X11 rear
- Engine Builders need advice in rod clearance
- transmission is broken
- Plans for car....ADVICE??
- cost effective LT1 clutch?
- Z28 Maintainance
- Combo Motorsports
- Trip-o-meter dosent work
- Headers for 96 LT1
- MSD System
- Where can I get a good deal on a T56 conversion for 95
- where can i find a 427??
- 285/40/17s?
- Will 18's in the back and 17's in the front mess with ABS
- Need O-pinions on the value of........
- Power Programmers
- Dex cool Coolant!
- 98+up TA tail lights
- will a tpi intake manifold fit on a LT1?
- Nitto or BFG's???
- Opti seals and a dead LT1
- Car Died, Dont know what to Do !
- fuel pump?
- will a lt1 run w/o front 02 sensors in?
- Cutout and CAT!
- Maybe its not the opti-spark!
- LCAs brands and type?
- cutouts???
- LCAs and Panhard Rod Install
- HELP! tranny blew and fluid all over my driveway! car wont move! 700R4 93 Z28
- Any good springs that dont lower? I have longtubes and little clearance.
- my dyno
- No more Dal?!?!?
- After installing WP, some seepage from the weep hole is normal?
- Hooker long tube screws and installation
- Difference between 93 and 94 Intake?
- Please critique my set up!
- Edelbrock catback???
- ZR-1's or 10 spokes whos got the best price?
- Alternator Squeeking...w/n
- 3100 series lobes again
- O2 sensor cleaning....
- Can anyone locate the CAGS wiring harness for me??
- ABS Wheel sensor
- roller rockers and parts
- Engine Light On???
- Traction Light
- What lowering Springs and shocks to buy?
- Anyone Got Part # For 1LE Elbow?????
- 7k for a camaro which one to get?
- Where do they lead?
- Tr6
- Coated Headers
- Torco converters
- Pistons
- How hard is it to swap a transmission?
- What you think about this....????
- oil pressure sensor
- buzzing sound from wiper area...
- Hey every1 come in here IM portant Question!!
- CSI pump install questions
- Reseting the ABS on my S-10 Blazer
- Help Quick!! Need To Prove Some Rx-7 Guys Wrong!!!
- Windshield wiper broke. What actually broke?
- open and closed loop, please explain to me
- automatic camaro crusing speeds
- Intake Gaskets...RTV or Not
- Difference in shifter between Hurst and Pro 5.0?
- What RPMS do you idle at?
- Howabout dual exhaust?
- need ASAP some bolt sizes
- TV cable help
- BLM's on scanmaster... Which side is which??
- Aftermarket A4 shifters?
- Slack in steering?
- Quick Driveshaft Question...
- GOING TO FLUSH oil what is the best flush or what do u use
- How much will 3.73's help me in the 1/8th mile?
- What good is a cam without 1.6:1 Rockers?
- Security light flashing, car doesn't start... what is it?
- brake pads & rotors
- Final 2.73-3.73 question
- Engine and transmission swap
- I NEED 2 93-up camaro/firebird WHEELs for TRACK
- Best roller rocker to buy?
- ignition and coil
- Opti rebuild
- How much for Engine tools (micrometers, etc.), what are the best?
- copper head gasket for LT1
- Anybody ever got faster by changing to a 255 fuel pump?
- Building the bottom end help
- how long do 6 speeds last?
- Thunder racing kit
- how much would you guys pay for this z?
- is a compression test a good way of telling...
- Replace Timing Chain w/ Hotcam kit?
- DSM Suspension?
- What is the heat range(#) of the stock spark plugs??
- Goal- 320rwhp
- Coated header cleaning & polishing??
- Mechanics in Jax Fl.
- Is it a V6 or V8?
- Please Help Me, My Car WONT start
- 383 or 396 Stroker kit?
- Please Help,cant Leave My House!, Car Just Died!!
- Changing Spark Plug wires ?????
- which 17x11 to get..the GS rim or the regular corvette zr1 17x11??
- anyone do a head swap with motor in the car?
- Cost of salad shooters
- Do fuel pressure regulators rarely go bad?
- Readend Question?
- 2.73 to 3.73
- What gauges?
- cat back questions
- PCV inline filter or passenger side filter?
- Question about O2 sensors...
- cutout running open for the last 2 years now. plugs go bad now??
- Just hit 83K on my car...what sensors plugs wigits and dodads need replacing?
- Lt1 Tb
- 383 with stock heads?
- Difference between 1LE and BMR
- What Cam Is Bigger Than Cc305 But More Streetable Than Cc306??
- Brakes
- Shooting Falmes?
- Header Gaskets
- QUICK HELP PLEASE: Will an LS1 FE2 steering rack work in my 94 Formula?
- Copper tubing alright for TB Bypass?
- electric water pump or not?
- SLP header for 1994 Z
- hesitation only in open loop
- Codes P1416 and P1657?
- slp LM+quad kit installation?????????
- Looking to buy 95, valve train noise, need advice
- has any one rebuilt or bought a rebuit opti?
- Swap LT1 rear to LS1 style Q's
- Poping noise while steering
- How do I read injector pulsewidth in Spd Dens 93 and 94-95 OBDI LT1 cars
- CAM Questions
- Can I remove the CAT at home?
- Torque Converter
- Why does the PCV just does a horse shoe back in?
- T-56 transmission
- are Relocation Brackets worth it with stock springs?
- Spal fan vs. dual lt1 fans
- what do the fuel corrections sit at on a car with nothing wrong?
- Gauge cluster switch in lt1
- shifting 3rd at 90
- $$265 for motor???
- Hey Shoebox...
- Windsheild wiper problem
- I need a decent clutch kit which can hold up to a 383... at least for a while :)
- Where is the BEST/CHEAPEST place to buy gauge pods and gauges??
- Please advise...heater doesn't blow hot for long...
- 4L60E Shift Improvement Module (Automatic)
- T56 rebuild...anybody done it
- Spec stage II clutch and LT4PP installed. Question..
- OH CRAP! I need help please, my friend fried my car!
- Headers- for my car long or short- please help.
- Is it in my head that my Z is really that fast.
- What oil is right for me (dyno too)
- Quick Question
- "Darn" Brake Pads!!!! Help!! (edited by moderator)
- XE 224/230 w/ hot cam kit? can i do that?
- squeaky clutch??
- Sounds of everyone's exhaust set-up
- Non LT1 ??? (You guys are good so I know someone knows)
- Is single Disc Mcleod clutch right for me?
- heating the coil springs to lower the car?
- Longtubes Or Roller Rockers
- Cam and valve spring Q's
- Need a car-fax please
- headers again
- Adjustable stops on Pro 5.0?
- Stock Injectors
- Does anyone know the difference in head bolt torque between 95-96?
- Quick hot cam question?
- strange problem w/ motor swap
- leak update
- Coolant Loss?
- Air Pump?
- Role cage
- More horsepower?
- Best $$$$ deal on LT4 heads
- Is this seal replacable easy?
- Question for Texas F-Bodies
- Who would you bring your LT4s to, to get ported?
- suspension
- Oil Leak
- help! cant not set valve lash
- cant get M6 into reverse
- cat
- Swapping the V6 for an LT1??Help Needed
- high flow cat?
- Magnaflow on an LT!
- Changing main bearings w/ motor in car?
- vibration at highway speeds
- Best Aftermarket Shifter
- just sent my pcm to brian
- Bank1 . . driver or pass side??
- LT4 Conversion
- creaking steering
- Oil Leak Help.
- If I want to Have LT4 clutch
- Best First Mod?
- problems with axle removal!!!!
- Upgrading to a 4th Gen
- lingenfelter 58 mm TB adjustment questions..
- Stock Cam Specs?????????
- So, when are the Bilstein HD going to be back in stock?
- DMS SFCs?
- Oh "Darn"!!! Borla Owners Come In Please! (edited by moderator)
- FAST with dif ignition system?
- slp header install questions
- What Ya' Think?
- Mysterious oil leak?????
- What LT1 year do think is the best??
- gear change
- 58 mm tb size
