Fuel Injector Size
Old Feb 7, 2003 | 08:42 PM
93ZM6Tally's Avatar
Fuel Injector Size
Had my car dynoed I'm making about 360Hp at the rear wheels. Wanted to replace my injectors. I'm currently using the original injectors, (22lb). I have some low RPM driveability issues and I've pretty much replaced everything else - thought I would put some new injectors in. I found a formula on Racenet. It recommend somewhere in the 33lb area - I was actually planning on going with 24Lb injectors. Any thoughts?
Old Feb 7, 2003 | 08:44 PM
IDOXLR8's Avatar
I think 24 lb injectors are good for 450 hp
Old Feb 7, 2003 | 08:56 PM
madwolf's Avatar
24 SVOs or 30 SVOs....
I'd actually go with some 30s. Just to be safe and also gives you a little more room if you plan adding more mods. You'd almost be maxing out stock 24 injectors with that power. Keeping them at high duty cycle all the time isn't too good of an idea...
Old Feb 7, 2003 | 09:07 PM
stik6shift93's Avatar
I'd run a 30 it'll leave you some head room for future modifications.
Old Feb 7, 2003 | 10:02 PM
Josh-'04 GTO's Avatar
This calculator should help you out...
http://www.smokemup.com/auto_math/fuel_injector.php
AdsoYo
May 2, 2018 03:21 AM
HectorM52
Jul 30, 2017 11:46 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
