Engine Builders need advice in rod clearance
Old Feb 7, 2003 | 08:38 PM
SABLT194's Avatar
I'm freshening up the bottom end while I'm putting on the new heads and just checked rod clearance. I'm using Clevite P series bearings and a bone stock crank. Plastigage is between .002" and .003". Isn't that a tad too much clearance?
Opinions please
Steve
Old Feb 7, 2003 | 09:10 PM
The factory manual says that 0.0030 is the max service limit and also says that production limits were 0.0013-0.0035. Sounds like you are not in bad shape as long as you have good oil pressure. A little loose will make it rev more freely.
Old Feb 7, 2003 | 11:42 PM
Ken95Z28's Avatar
The .003 is the max that you would want.
I set mine up to .0025 and the mains were set at .002
When I freshened up mine the rods were at .003 I went out and bought a half set of .001 oversize bearings and put them on one end of the rod bearing and the standard size on the other.
Old Feb 8, 2003 | 05:55 AM
Mtrhds94Z's Avatar
I agree with Ken here that mixing a set will get you a little tighter[it's done often]
.003 is a bit loose... .002-.0025 is good.. for SBC
Roadie
Feb 16, 2015 10:34 AM
Chevyguy358
Jan 28, 2015 08:04 PM
Bearmans
Dec 3, 2014 05:28 AM
GA93FORMULA
Jul 24, 2002 11:38 PM
