Is this seal replacable easy?
Old Feb 5, 2003 | 10:59 PM
94-3.4's Avatar
The front crankshaft seal is leaking on my timing chain cover. Can i replace this seal just by pulling the crank hub off or does the timing chain cover need to come off? Thanks
Old Feb 5, 2003 | 11:12 PM
The timing cover does not have to be removed. Mark the position of the hub to crank before you remove the hub, so you can put it back on in the same position.
Old Feb 5, 2003 | 11:19 PM
94-3.4's Avatar
Great, that is what i was hoping. Thanks
Old Feb 5, 2003 | 11:39 PM
KCFormula's Avatar
Why do you have to mark the hub? What happens if I get a keyed hub?
Old Feb 5, 2003 | 11:59 PM
If you mark the hub relation to the crank, then the pointer position will be maintained when you reinstall the hub. It is useful for setting valves and also to maintain balance if your pulley happens to have any balancing weights in the little holes (most don't).
If you go keyed, it can only go on one way.
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Jazsun
Dec 29, 2014 12:14 PM
pologreen97z
Dec 2, 2014 10:42 AM
The Seer
Nov 20, 2014 06:32 AM
