Windshield wiper broke. What actually broke?
Old Feb 7, 2003 | 10:02 AM
Z95m6's Avatar
This morning when i turned on my wipers the drivers side was frozen down and i didn't know it, so the drivers side stated down but the passenger side came up. So after i unstuck the driver side when i turn on the wipers only the passenger side goes up and down. So the ? is what did i probably break? Also is there any place on the net that would show me how to get down into the wiper area so i can look around?
Thanks Mike Allen
Old Feb 7, 2003 | 10:04 AM
turbo_Z's Avatar
dude, im guessin your wiper motor bit the dust.
Old Feb 7, 2003 | 11:09 AM
Z95m6's Avatar
unless each arm has a wiper motor i don't believe it could be that because the passenger side works fine. If it is anything like my mach i assume there is a steel arm going to the wiper and it has a clip on it so either the clip broke or the arm but it maybe total different than the Mach.
Old Feb 7, 2003 | 11:41 AM
97ss1826's Avatar
My girlfriends Camaro did the same thing last year. All that happened on hers was the nut that holds the arm down to the splined shaft came loose. It wore some of the splines down a little bit but I was able to put it back on and tighten it. Still works a year later.
Old Feb 7, 2003 | 12:10 PM
Mtrhds94Z's Avatar
Either one of the 'ball and socket' joints popped off, or[more likely] the tapered splined wiper shaft[ that the wiper arm goes on] stripped...
With luck removing, cleaning, and retightening that will work[the arm is 'die cast[soft] and the shaft is harder steel, so the splines in the shaft will be intact, and you'll be 'cutting' new ones when you reinstall it..
Charlie
Old Feb 7, 2003 | 08:05 PM
Z95m6's Avatar
Charlie
That was the problem the splines on the wiper arm were stripped. I just took the arm off cleaned and retightened it. Its good as new but naturally as i was taking one of the plastic covers off in the cold it broke oh well at least i have wipers. Thanks guys.
Old Feb 15, 2003 | 09:28 PM
airos4's Avatar
May sound like a stupid question, but the same thing happened to me - how do I access the arm and remove the plastic covers to get to that nut? I need detail, or else I'll seriously screw up my car...
Old Feb 16, 2003 | 08:58 AM
shocktrp's Avatar
The plastic covers pop off.
I think they are about $8 each from the dealer when you break them.
truecontr3
Oct 11, 2015 09:30 AM
autoxr166
Sep 25, 2015 04:21 PM
DelSoto
Sep 19, 2015 05:31 AM
Henson071
Sep 18, 2015 04:01 PM
Daluchman1974
Sep 11, 2015 06:12 AM
