just sent my pcm to brian
Old Feb 5, 2003 | 09:09 PM
94ltwonz28's Avatar
what all can he do to my pcm? can he adjust timing and a/f ratios?
there wasnt a spot on the form but I also asked to bump up the shift points and rev. what all can be done?
thanks
Ross
Old Feb 5, 2003 | 09:27 PM
96ZRDR's Avatar
On your car he can:
-set rpm limits
-set Trans shift points
-adjust target air/fuel ratio
-delete codes related to EGR, Rear 0'2's, Air Pump
-Desensitize you Knock Sensor' set lower max retard or complete eliminate knock values.
-adjust fan operating tempatures
-adjust idle rpm
-adjust for gear change, speedo calibration
-perform his own power programming.
and host of other things.
Do not use the form, send him an e-mail and tell exactly what you want. You wont look back! He a great guy to do business with. He'll take care of you
Old Feb 5, 2003 | 09:30 PM
95TA8280's Avatar
What would changing the idle do?
Old Feb 5, 2003 | 09:41 PM
94ltwonz28's Avatar
Originally posted by 96ZRDR
On your car he can:
-set rpm limits
-adjust idle rpm
very cool, my car is running like total crap and I dont think its the low rpm stumble, I repaired some intake leakes in the elow and I think that was the problem all along, car is still a dog down low, almost as if its too rich.
Old Feb 5, 2003 | 10:00 PM
96ZRDR's Avatar
94ltwonz28,
I would be weary of changing your air/fuel ratio if running some nitrous. Are you running wet or dry system? To keep it safe you may want to leave that stock. I suppose you wanted to lean it out?
Changing idle will not do anything, but many cammed car owners like to raise the idle to avoid cam surge, and just plainly allow the car to idle a little smoother with bigger camshafts.
I was just listing some of the things Bryan is capable of doing, not neccessarily telling you what to do.
Good Luck, and like I said tell him your story, and he will set it straight.
Old Feb 5, 2003 | 10:23 PM
94ltwonz28's Avatar
no longer runnin n20, traded it for hotcam kit, I would like to go a little lean and get rid of all the knock crap.
Old Feb 5, 2003 | 11:15 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
its bryan
and just tell him what u have and tell hium to make you go fast
Nayr
Mar 3, 2023 08:34 PM
LT14LIFE
Nov 15, 2015 06:22 PM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
