I think im in trouble!
Old Feb 7, 2003 | 10:55 PM
thelategreatz28's Avatar
Flushin my coolant and when took off the thermo to flush block, coolant got all over opti. And I accidentally spilled water from the hose onto it becuase i cant freakin aim into the water pump! What the hell does this mean??????? I just got opti replaced 30k miles ago and I dont wanna do it again! What should i DO!
Old Feb 7, 2003 | 11:01 PM
AENIMA95z28's Avatar
You should be ok man, your opti was designed to withstand being wet. Granted it wasnt designed to get soaked with coolant i dont think its going to hurt it as long as you cleaned it off. Do you see any signs that the opit is messed up (feel like spark is retarding?), becuase if you dont now you most likely arnt going to later.
Old Feb 7, 2003 | 11:08 PM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
You should be ok, just as long as it's not a constent thing.
Ericksd
Jan 20, 2016 06:07 PM
ZXXVIII
Sep 1, 2015 10:13 PM
Schul365
Aug 22, 2015 10:00 AM
Aug 7, 2015 01:26 PM
surreybrad
Jul 5, 2015 10:36 PM
