Drag wheel and tire ?
Old Feb 8, 2003 | 12:04 AM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
I want to run a 28x10.50 slick. Will they rub? I'm guessing I need a 15x10 wheel. What back spacing do they need to be(7.5 maybe) I don't mind pounding out things here and there just not sure what will work and what wont.
Old Feb 8, 2003 | 12:10 AM
Yes. But if you mean a 28x10.5-15W, you will have to do some serious pounding on the inner fenders.
15x10 wheel, 7.5" BS. I ran QTP 28x11.5-15's with no problems until trap speeds went over 125mph... then the tires were growing enough to start hitting the edges of the wheel opening. Just moved the axle back about 1/4" and let the tires "radius" the rubber bumper cover.
Old Feb 9, 2003 | 08:03 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
i cut out the bump stop support and pounded in the inner well in front of the rear tire. fred is right.... i am running the 'w' on my car.
Old Feb 17, 2003 | 06:06 PM
PNYKILR's Avatar
I forgot I even posted this. Thanks for the input guy's. I dought I'll put a W tire under this car but, you never know.
carguy0119
Apr 11, 2016 11:11 PM
HarleyZ28
Oct 5, 2015 06:23 AM
dpw21562
Jan 23, 2015 04:58 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
