Will 18's in the back and 17's in the front mess with ABS
Originally posted by frmula1
well, no, that would only be true if you put a larger tire on the 17's... but i don't see how diameter should **** with the abs anyway...
Originally posted by madwolf
AFAIK, there are no speed sensors on the front wheels....
Computer only cares about the readings from the back to measure speed.
Wrong.
It does have front speed sensors.
Besides, if it didn't, how would the computer know if the front wheels were sliding? If the tire diameter is different, then the computer will think the wheels speeds are different. Therefore, every time you hit the brake you would get what's called false cycling.
Yes you're right. It does have front wheel sensors, but I am not sure those go to the actual pcm. They might serve just for the ABS because vehicle speed to the pcm and speedo is measured using the rear sensors...
Hmmm..... how are they dealing with this problem on the Vettes then?
You could actually recalibrate the Camaro PCM to do the same thing, BTW.
What you're saying doesn't make sense to me. I have been programming computers for a while now and I've always programmed according to the size of the rear wheel. There aren't separate settings for the front and rear wheels.
When I began to do this, that's what everyone said. The speed in the pcm is measured from the rear wheels ONLY.....
I also remember someone on the lt1_edit list talking about somehow adapting the rear wheel sensors to work on the front wheels because he had a custom rear to which you could not adapt speed sensors. I remember they were joking about what would happen when the front wheels would be in the air....
