Slack in steering?
Old Feb 7, 2003 | 01:22 AM
blkn'silver94's Avatar
Slack in steering?
If i have slack in my steering wheel..what do i have to replace?..what am i looking at here?
Old Feb 7, 2003 | 01:30 AM
Compstall's Avatar
Put the car up on jacks and have a buddy turn the steering wheel back and forth while you're underneath lookin' around. Wiggle the wheels up/down left/right, pull on the steering arm joints. And the worst it could be is a worn steering rack.
- Brent
Old Feb 7, 2003 | 01:44 AM
i hit a curb...i was thinking more like what did i damage.
Old Feb 8, 2003 | 12:07 AM
Donny O's Avatar
could have damaged anypart of the steering but my first guess would be tierods. you can even do it with the car on the ground....grab a wheel and see if you can move it whilethe stering is locked(ignition off)...it shoudn't move hardly at all...but watch where the outer tierod connects to the steering knuckle/spindle and see if it is loose there. I jsut replace the right and left on my car!!!
Old Feb 9, 2003 | 02:17 AM
how much am i looking at?
Old Feb 11, 2003 | 05:53 PM
Donny O's Avatar
tierods were like $25 a peice(2 inner and 2 outer, but I only needed outer) and $20 to change them($40 total for 2 of them, but mine needed to be hearted witha torch and all to get them off....I was unable to do it myself, but you might be able to) and $50 for alignment afterwards.
Old Feb 11, 2003 | 10:36 PM
thanks for the info.
Old Feb 11, 2003 | 10:44 PM
Donny O's Avatar
you should also be able to take it to about any shop and they will inspect it for you and tell you what is wrong....jsut hope they don't lie to you!!!! good luck!!
Old Feb 12, 2003 | 01:13 AM
96 WS6's Avatar
You have headers? Try a rag joint eliminator for your sterring linkage... www.unbalancedengineering.com Mine started having slack about 3 days after I put my headers in and I still need to order this piece, it's supposed to make it go away.
Old Feb 12, 2003 | 05:40 AM
HungryT/A's Avatar
Wow, that's great. That's what I have custom made for my car a year ago! Jeez, they stole my idea!
That's the best 'mcguyver' stuff you can do to your car. It makes your car response so well, it's unbelievable!! It feels like my friends beemer's steering!
HibachiZ28
Nov 6, 2015 12:53 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
rideordie
Sep 7, 2015 08:22 AM
War Engine
Aug 28, 2015 06:04 AM
Schul365
Aug 25, 2015 05:47 PM
