cant get M6 into reverse
Old Feb 5, 2003 | 10:27 PM
needacar's Avatar
just picked up my car tonight and i now cant get the thing into reverse, its happened a couple times now and now it just wont go in. The first time i EVENTUALLY got it into reverse now it wont go in at all, stock shifter on it. Also it will make some grinding type vibration noises when i floor it at low RPMs in like 3rd and 5th gear i beleive but ive heard thats normal. what should i do, what could be causing it, hope it doesnt already need a rebuild. I have a hurst shifter sitting in the car just not installed, any help is appreciated
thanks
danny hollis
Old Feb 5, 2003 | 11:10 PM
kgkern01's Avatar
Sounds like a bad reverse synchro. Does it go into reverse with engine off, key in ON position, but wont go in with engine running? If so, chances are bad reverse synchro. I had the same problem, turns out I also had 2 bad bearings in the tranny, but all other synchros, blocker rings, gears, bearings were in great condition, so shop just replaced what was necessary.
Old Feb 5, 2003 | 11:26 PM
needacar's Avatar
Angry
man i have a bad synchro already, thats wonderful. Oh well i shouldve expected that with my luck. Oh well do i need a full rebuild? It shifts in reverse everynow and then, but not often enough and i can put it in reverse with the car off
everyother gear seems to shift fine. let me know
thanks
danny hollis
Old Feb 5, 2003 | 11:29 PM
madwolf's Avatar
I'd start with a good ole' tranny fluid change. Get some Mobil 1 synthetic. See if that changes things.
Also, before switching to reverse, shift it into 3rd, then 4th, then reverse... try that and see if it works..
Old Feb 5, 2003 | 11:40 PM
slashz28's Avatar
what madwolf said
Old Feb 6, 2003 | 01:03 AM
JCSWS6's Avatar
Before you spend any cash check the tranny an make sure everything is plugged in. I put a skip shift in the wrong spot once and the car would not go into reverse.
Old Feb 6, 2003 | 01:10 AM
Joe Brodman's Avatar
GP Moderator
Exclamation
If it is anything electronic (which not going into reverse would be the reverse lockout solenoid not disengaging), you still can get it into reverse. Just have to push a little harder.
If it won't go in with a hard push, then it isn't the lockout solenoid....trust me, that thing isn't THAT strong.
Old Feb 6, 2003 | 01:24 AM
Jason Dove's Avatar
Try raising the clutch petal... on my car I had the same problems.
My buddie's LS1 was doing the same thing from the factory, raised his petal about 1/2 and inch and it stopped crunching and reverse got easier... just like what happened on my car.
Old Feb 6, 2003 | 11:21 AM
needacar's Avatar
update so far,
the car will go into reverse MUCH more frequently now. It will now go in probably 1/2 to 2/3s of the time that i need it. But it seems to start getting harder to put into reverse the longer i drive it. For example this morning when i went to go drive it it would go in cleanly and smoothly many times and the more i drove it it would slowly seem harder and harder to get it in, though it would normally go in most of the time. WHat do you guys think?
please let me know and all help is very appreciated
thanks
danny hollis
Old Feb 6, 2003 | 11:29 AM
LimitedEd1LE's Avatar
The reverse solenoid lockout might be bad. Also make sure that the car is not moving when you put it into reverse, because i know on mine if i am moving at all it won't let me go into reverse.
Old Feb 6, 2003 | 11:32 AM
needacar's Avatar
where do i find the reverse lock out solenoid?
sorry im new to these cars i used to have a turbo buick so F-Bodys are all new to me
thanks
danny hollis
Old Feb 6, 2003 | 02:14 PM
2MCHPSI's Avatar
Danny, you can blame it on the centerforce clutch I am thinking. Considering it happens after it warms up. The synchoro is fine and the fluid is fresh. Always shift to first before going into reverse. The clutch is also fine (only 3k on it), but there are known problems with centerforce clutches after they warm up on these cars. It has to do with its inherent design and clearance issues to the flywheel. The aftermarket shifter for some reason helped a lot when I had it installed, and I never even really considered it a problem. You will get the NORMAL vibrations much more pronounced with the aftermarket shifter due to the lack of the isolator bushing though. I just want to make sure you know the tranny is not about to explode or anything like that
Do a search on centerforce clutches and you will understand a little better. The good thing is the centerforce clutch on your car does not have any serious problems like some other have experienced (other than the reverse issue you are having). That clutch held up fine to over 450 h.p.
Old Feb 6, 2003 | 06:13 PM
needacar's Avatar
thanks kevin, as always i appreciate it
im gonna put the hurst in probably tonight or tomorow night
thanks again for everything
seeya
keep in touch
RUENUF
Mar 13, 2016 03:37 PM
blac94Z
Nov 4, 2015 01:59 PM
dolfan324
Jul 17, 2015 10:34 PM
Beave2780
Jul 7, 2015 06:36 AM
jimlab
Oct 6, 2002 08:37 AM
