Best roller rocker to buy?
Old Feb 6, 2003 | 10:30 PM
foggerZ's Avatar
Question Best roller rocker to buy?
I was just wondering which RR would be the best to put in my 93' Z. I'm stuck between the Comp Cams Pro Mags, and the Crane Gold race. Does anyone know if the Comp Cams Pro Mags will fit under the stock valve cover. If so, which one should i get? The self aligning 1.6's or the non- self aligning ones. I believe that self aligning RR's should be a drop in Right? I would have to use guide plates and hardened push rods to use the non-self aligning ones. any and all help and ideas are apprecisted . Thanks
Old Feb 7, 2003 | 06:39 AM
IDOXLR8's Avatar
If you do a search you will find out alot of useful info
Old Feb 7, 2003 | 09:02 AM
93Z4ME's Avatar
I've been researching the threads on this subject for awhile for my 93 and here is what I've concluded.
1) yes the self aligning (SA's) are a less expensive alternative upgrade because you don't need to change as much stuff,
2) SA's are much noisier, but on our 93's we don't have knock sensors that are effected by this extra "knock sound" so it's just anoying.
3) Everyone recomend changing springs and retainers when doing this mod because with the higher lift ratio it is just safer to do so but not strictly nessesary.
4) Non-Self Aligning do require guide plates to keep everything pointing straight and guide plates require hardened push rods.
I will probably go with the NAS option because I don't like needless noise and will call Crane to put together a kt for me.
However.... There is a GM LT4 "HotCam" kit from Sam Taylor Chevy that includes cam, SA Rockers, Springs and retainers for about $465 that will really wake your engine up and that is a very tempting package (the heck with the noise!)
http://www.samtaylor.com/html/parts.html
LT4 Hotcam Kit
P/N 12480002
Only $465.00
Old Feb 7, 2003 | 09:24 AM
ZZtop's Avatar
The only thing the kit doesnt include is lifters, which I consider a must when changing a cam. What lifters are yall running with this cam kit?
Old Feb 7, 2003 | 09:32 AM
teke184's Avatar
can the added "noise" be remedied with the use of an LT4km? or is there enough that even that doesn't take care of it all?
Old Feb 7, 2003 | 09:37 AM
93Z4ME's Avatar
Replacing lifters on a "rollor cam" is not strickly required because unlike flat tappet cam/lifters the lifter doesn't set up a wear pattern which would ruin a new cam. That said, yes old lifters (espesially on a high-milage 93) will probably be weak and may even have damaged rollers, (which is usualy caused by overreving and the roller departing or bouncing off the lobe of the cam) so it would be best to change them as log as you're in there. I plan on running new stocks since they seem to work well and I've never heard anyone having problems with them (or any other for that matter)
Old Feb 7, 2003 | 01:38 PM
foggerZ's Avatar
Question
Does anyone know if CompCams Pro mags Rollers will fit under the stock valve cover? Self aligning or non-self aligning or will both fit?
Old Feb 7, 2003 | 01:56 PM
Don 97 SS's Avatar
My sa Crower stainless full RRs fit under the oem valve covers.
LeftoverChinese
Jan 14, 2024 03:03 PM
oldschool
Feb 9, 2016 09:21 PM
HarleyZ28
Oct 5, 2015 06:23 AM
dfarr67
Apr 10, 2015 07:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
