Pistons
Old Feb 7, 2003 | 12:26 PM
Mr_Superman's Avatar
Pistons
I will soon be doing some slight engine work on my car (cam, etc...) I have plans on putting nitrous on my car maybe a 100-150 shot.I was wondering if while I am working on the engine should I replace the pistons and rings, with some forged pistons and total seal rings? What can an lt1 handle nitrous wise?
Old Feb 7, 2003 | 01:32 PM
Derrick Redd's Avatar
Forged pistons will raise the safety factor. I spray 150-175 on my stock shortblock. It pulls almost 126 mph traps without issues. (so far ) I see most people not having problems with up to a 150 shot on a stock bottom-end motor. Just make sure you have a good tune and enough fuel.
Old Feb 7, 2003 | 01:56 PM
How much safer would I be with forged pistons? O=I am caught in between doing pistons, gears, or torque converter.
Old Feb 7, 2003 | 02:05 PM
IDOXLR8's Avatar
It will make your car alot safer if your car is tuned properly for nitrous. If not it will get damaged just like a stock piston. I would recommend against Total Seal if your car is a daily driver. There seems to be alot of oil consumption problems with these rings.
Old Feb 7, 2003 | 02:59 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
ur going to change the pistons/rings without machining the block?
just wait
if they go, they go, tehn replacem
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
