connecting rods...
Old Feb 7, 2003 | 08:50 PM
GoTopless95Z's Avatar
connecting rods...
I need to know what the stock sizes are for a '95 LT1 connecting rods. I've got a set of Eagles with the following sizes and need to know if they will work in a stock rebuild.
Center to center 6.2"
Big end bore 2.225"
Pin bore .928"
Anyone know!?
Old Feb 7, 2003 | 09:36 PM
c5formetoo's Avatar
5.7 long
2.100 big end
.928 small end
those will not work in any small block chevy
Old Feb 8, 2003 | 05:58 AM
badass383's Avatar
Sorry the fat end of the rod is 2.225. 2.1 is the crank. Don't forget you need the clearance for the bearings. Stock are 5.7 long. Were you planning on changing the compression ratio? You could use the 6.2's but you would need to change to a smaller compression height piston. Dished too. I'm using a 3.75 stroke with a 6 inch rod. The stock 3.48 stroke with a 6.2 would work.
Old Feb 8, 2003 | 08:07 AM
c5formetoo's Avatar
badass383......you need to check into your numbers.the rods are 2.100 the mains are 2.500 on every lt1 i have ever seen.plus the guy asked if they would work in a stock rebuild so his answer is no.also the lenth of the rod will affect only the compression height.there is no affect on the compression ratio so there is no need for dished.
Old Feb 8, 2003 | 10:15 AM
stik6shift93's Avatar
Don't go for the 6.2 inch rod if you plan on doing an spraying.
Old Feb 10, 2003 | 02:29 PM
badass383's Avatar
[QUOTE]Originally posted by c5formetoo
badass383......you need to check into your numbers.the rods are 2.100 the mains are 2.500 on every lt1 i have ever seen.plus the guy asked if they would work in a stock rebuild so his answer is no.also the lenth of the rod will affect only the compression height.there is no affect on the compression ratio so there is no need for dished. [/QUOTE
Scuse me ********, rods for 350's use a 2.225 crank jurnal. The crank is 2.100 with bearings of .062 on each side of the crank, the rod has to be 2.225. When you shop for rods you buy them for 2.100 cranks but the rods themselves are 2.225. I got 8 stock rods I pulled out and 8 Oliver rods that are 6 inch and quess what, they all have 2.225 crank journals. But since you never built an engine you wouldn't know this. Stay where you belong. out of technical conversations.
Old Feb 10, 2003 | 02:55 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
[QUOTE]Originally posted by badass383
hey-
first off right or wrong-
stop bieng a jerk. C5 has been here for a few months and has already made a good name for himself as a good and knowlagable guy.
you've been here for 10 days max and your already being a complete jackass- and your spelling is worse than mine. from the sounds of things- I think he could build a better motor than you.
You CAN NOT a rod of that lengthin an LT1 unless you DESTROKE it. I am unsure about the journals. increase compression with a longer rod and deep piston? Have you ever looked at a piston before? This might be the dumbest thing i've heard all week. who the hell built you motor? if you use a longer rod to increason compression your also increasing the number of a times your piston smacks you heads.
maybe YOU should stay out of technical discussions for several reasons-
1. your so wrong I dont know if i should steal your tools or buy you a book
2. your a jerk about it at that
and just for the record-
I built a motor
sorry if i came across as bigger jerk than you, but things like this really **** me off
Old Feb 10, 2003 | 03:29 PM
Mineral's Avatar
As far as Rods, just make sure they're as big as the Cones, and you'll be alright.
Old Feb 10, 2003 | 03:42 PM
rskrause's Avatar
Moderator
LOL
You can use the rods, but they are pretty long for a SB Chevy. Some people are using rods up to 6.25" though. Of course, you will need new pistons with 6.2" rods.
Most people use rods between 5.7 and 6.0", with stock being 5.7". If I were buying new rods I think I would go for 5.85", reflecting my basic indecisiveness!
Rich Krause
Old Feb 11, 2003 | 02:17 PM
arnie's Avatar
Originally posted by treyZ28
hey-first off right or wrong-
Not about to say who is or isn't a jerk, but c5 DID state, not once but twice incorrect info. Badass DID politely correct him, (the 1st time) with good explanation.
As far as your statement of requiring destroking, actually if you do the math it IS possible. 396 stroke, (+.395") can be used w/6.0" rod (+.300"). The 6.2" rod w/stk. stroke is +.500". So, it is possible, trey. Take care. BTW, ever here the one 'bout arguing on the internet and the Spec. Olyp.? Inquire off list if necessary.
Old Feb 11, 2003 | 04:03 PM
treyZ28's Avatar
yea but C5 never resorted to name calling-
yea sure u can use it, with am almost custom piston. **** you can do almost anything...
how about the compression thing???
Old Feb 11, 2003 | 04:09 PM
WS6T3RROR's Avatar
pin gets higher up the the piston compression stays the same all things being equal. piston gets weaker from being so short. whats goin on under the piston dont have much to do with whats goin on over it.
Old Feb 11, 2003 | 04:11 PM
treyZ28's Avatar
connecting rod length in completely independant of compression.
quench hieghts are very very little when compared to the differenaces in connecting rod lengths.
use a longer connecting rods and you'll slap the heads off the car
Old Feb 11, 2003 | 05:02 PM
WS6T3RROR's Avatar
you can use a 6" rod in a 383 right trey and i even bet that you have them in your engine. difference between a stock stroke(3.48) and a 383 stroke (3.75) is .27 and then take the diff between a 5.7 rod and a 6.0 rod and you end up with .3 add the two together and you come up with .57" of distance that you have moved the pin up in the pistons in your engine. so when you take the number thats even smaller than is used on your engine .57 compared to .5 that i need to run a 6.2" rod in a 350 i still come out with room to spare. so if i cant use a 6.2 rod in an sbc you cant have a 383 with 6" rods. and what about those pesky 396 guys with 6"
Old Feb 11, 2003 | 05:27 PM
treyZ28's Avatar
id just saying they dont make pistons readily available and "off the shelf"
buying 6.2'' rods would be silly
am i the ONLY one who saw the compression thing?
