slp header install questions
i just recieved some slp shorties that i bought used, their chrome , chremic coated i think....anywho what flange gaskets ,header gaskets and bolts do i need .... thanks for the help..
Complete kit:
http://www.slponline.com/view_produc...RTNUMBER=30029
Or you could just buy the flange gaskets from them & buy the header gaskets & bolts from any parts store:
http://www.slponline.com/view_produc...RTNUMBER=30031
95 black on gray leather z28 with odbII dualcats
Also why won't the 1406s work on both sides?
yeah it might be odbI but it has dual cats odbII connectors and i dont feel like changing my sig. anywho the one slp header flange is really big triangle shape like pictured in the pictures above ... and what header manifold gaskets, header bolts???how long are the header bolts suppose to be?? thanks for the help
ok on the 1406 flange gaskets... on the one triangler side you dont use a gasket?one side is a different shape ,because i dont see the 1406 working on that side but the other side it will....????help please
Not to sound like an *** or anything, but what are you talking about on the 1406 gaskets?? I used the set with no problem at all. That, and I got a set of header bolts from autozone for $3.99. Just retorque after the engine warms up and cools down once. Get some high temp RTV and put a little on the 1406 gaskets so they won't blow out(cheap insurance). I dont' know about the gaskets that go in between the headers and Y-pipe though.
John
John
jim88iroc305
Aug 13, 2002 09:24 PM
Wilson
Jul 21, 2002 05:08 PM
