leak update
leak update
this is what my previous message siad..
hey today i woke up and there was a big puddle under my car..it looked white..the groud was really wet to so it kinda mixed with it..car drove bad today when i took it to work..it had a weird idle..when i had it in drive and my foot on the brake the rpms would move about 3 hundred. any ideas?
now today about 2 days later i went to start my car and it wouldnt turn over for about 5 seconds then it did and the front end made a little bang...after that i turned the car off and tried to start it again and i turned the key and nothing happened..then i turned the key back and took it out and my security light was on and i couldnt push down on the brake..that was with the car totally off and the doors closed..the car then started up next time i tried and if i pumped the brakes they would get tougher and evenually lock up....still nno idea on the fluid leak..any ideas????????//
well...did you check all your fluids? how about checking to see what kind of fluid was under your car. better question is why were you driving on it....loud bangs from the front of the car when you start it usually arent a good thing. check all your fluids man.
Re: leak update
Aug 24, 2015 06:41 AM
Noct
Jul 14, 2015 01:18 AM
