Intake Gaskets...RTV or Not
Old Feb 7, 2003 | 08:59 AM
Teal94Z's Avatar
Just wondering, I am fixing my intake leak for the last damn time right now, wondering if you guys used rtv, I am gonna put some around the ports...any other suggestions? Thanks
Old Feb 7, 2003 | 09:04 AM
Smoke T/A's Avatar
I never had to use RTV around the ports. I ususally only put it on the front and rear of the block and half way up the head. Never had any intake leaks? You have to get the surfaces really clean befor you start laying rtv down. Are you torquing the intake in the sequence and to GM specks???
Old Feb 7, 2003 | 10:01 AM
Dr.Mudge's Avatar
Front and back only, the other gaskets are dry. You do NOT want RTV inside the engine, so I'd suggest not trying it, to do a good job it would take you a very long time anyhow.
Old Feb 7, 2003 | 10:03 AM
rasilverbird's Avatar
Do not put the RTV around the ports...it will harden, break off, and fall into the combustion chamber. Just put it on the front and rear of the intake.
Old Feb 7, 2003 | 12:53 PM
Teal94Z's Avatar
Thanks guys, ya I know to put a healthy bead on the front and back, but this last time I had overtorqued the bolts, and it caused a small oil leak into the intake ports, which caused a little bit of blue smoke at idle....thanks, Luke
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
MadMav
Jun 15, 2015 09:51 PM
jwade88
Jun 14, 2015 09:38 PM
Countryboychevy
Jun 13, 2015 02:49 PM
maybe2fast
Mar 26, 2015 08:34 AM
