Anyone have a problem after they installed a Walbro fp w/o the bucket?
Old Feb 8, 2003 | 12:57 AM
Alan566's Avatar
I read a lot of posts about using/not using the bucket in a walbro install but have not read any posts about anyone having a problem after they didn't use the plastic bucket.
Anyones walbro burn up or fail early because they didn't use the bucket?
If you have installed a walbro pump w/o the bucket how long has it run so far?
I am trying to decide on useing the bucket are not. thanks alan
Old Feb 8, 2003 | 08:29 AM
Alan566's Avatar
You ever run very low on fuel are run out of fuel w/o using the bucket?
Old Feb 8, 2003 | 10:10 AM
David94TA's Avatar
We decided not to use the bucket on my install and have had no problems. I watch the gas guage and don't run real low on fuel either.
Old Feb 8, 2003 | 10:12 AM
RamAir95TA's Avatar
It's there for a reason. Using it would be a wise idea.
I'm sure Jack could chime in on this one...
Old Feb 8, 2003 | 10:32 AM
Alan566's Avatar
thanks but no thanks. lol i have read most all posts about this topic and can almost recite word for word what Jack will post. The question i am asking is has anyone had any trouble with the pump after the install. its easy to say what might happen, i would like to know what has happened. It looks like a lot of people have done this mod and no one has said they have had a problem with it so far. I know someone has run out of gas at least once since the install? Anyways Jack don't want to talk to me because I am gonna cut a hole in my car!
I have not taken my old pump out yet but looking at all the pics i have seen i still don't understand how you will get air in the pump if you cut a hole in the bucket. It only sucking fuel from the bottom of the pump which has a sock that is not in the bucket right? I have done a lot of mods to my car and most aftermarket suff has to be modified anyway
And for the hole in the car, if its like all the older camaros i have had in the past the hole over the tank want be as big as the holes in the floor boards after a few more years anyway.lol
If no one has had any problems w/o the bucket than why should I? Alan
Old Feb 8, 2003 | 11:01 AM
RamAir95TA's Avatar
If you're going to cut a hole...here's a good link (this is my car and my guide. ).
http://www.worldisround.com/articles/12533/index.html
Old Feb 8, 2003 | 01:44 PM
Alan566's Avatar
thanks man, but i already saved that sight. By the way you did a great job, hope mind looks half as good as your when i am through. thanks alan
Old Feb 8, 2003 | 01:47 PM
RamAir95TA's Avatar
No problem man.
Old Feb 8, 2003 | 03:02 PM
Fear The Z's Avatar
I have installed the pump about 2 years ago with out the bucket...I havent had any problems yet :::knock on wood::: Ive been down to 1 gal. left in the tank....
Old Feb 9, 2003 | 07:57 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
no problems here
Old Feb 9, 2003 | 08:12 PM
GhostZ's Avatar
No bucket and no problems here.
Old Feb 9, 2003 | 09:29 PM
funina91ss's Avatar
I have no bucket but I have ran out of gas once gauge said around 8th of a tank but I am used to driving my 3rd gen which I cut a whole in both cars for the pump install. but I can run the 91 on e for a while but the 95 I fill up before it gets to an 8th of a tank.. other than that no problems at all.
Old Feb 9, 2003 | 10:16 PM
1RedHotZ28's Avatar
Well...I might be one of the select few that has had a terrible time with it...w/out using the bucket
When mine gets below half tank, and while making a right hand turn, it will starve for fuel BADLY and my gas gauge will go from 3/4 - 1/4 and back again when going around curves...
I intend on pulling it back out this spring, using the bucket or possibly just buying a stock replacement....this really sucks
Billy
Old Feb 9, 2003 | 10:51 PM
pasmado15's Avatar
to be or not to be without a bucket
I have been driving for 6k without any problems...
I've driven up and down steep hills and sharp curves (routes 66, 28 and 219 in PA and Freeway 68 in MD) with no problems. Nice drive especially while doing 2k RPM (70 to 80 MPH) and one can hear popcorn!!!! life is good.
Just to check the adjusted fuel float arm, I have refilled twice with 15.0 and at another time with 15.3 gals (and the manuals state only 14.7 gals to top off these tanks. Seems the fuel/vapor expansion canister is now my auxilary fuel tank---funny huh? No fuel fumes or leaks exist either. (I carry now a 1 gal fuel tank for emergencies)
I agree about the air issue you mentioned---it goes not make any sense since the "intake port" is outside the original bucket anyway. I think the bucket is only used to keep the pump submerged for cooling effects...
Happy trails
Old Feb 9, 2003 | 11:43 PM
6Speed's Avatar
So if you decide to keep the bucket, what has to be modified for everything to work properly? (Assuming you use a walbro pump).
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
CaRParts102
Dec 6, 2014 08:45 AM
thenewkid
Nov 29, 2014 04:54 PM
