shifting 3rd at 90
Old Feb 6, 2003 | 01:13 PM
Grn96Z's Avatar
shifting 3rd at 90
ok is it normal for me to have to shift out of 3rd at around 90 mph? I realized yesterday that I was almost at 6 grand in 3rd at 90 and had to shift to 4th?? What gear are you guys that are mostly stock in at 90?
Old Feb 6, 2003 | 01:20 PM
Dr.Mudge's Avatar
I could hammer second on the freeway, with a 7k limiter, but CA traffic sucks.
www.f-body.org/gears
Old Feb 6, 2003 | 01:26 PM
n2ceptor's Avatar
A4, 3.42 gears, 115-120 MPH shift from third....
93Z Will
Old Feb 6, 2003 | 01:29 PM
96ZRDR's Avatar
I have 6500 rpm redline and shift into 3rd around 90-95mph. Something is definetely wrong with your set-up.
Old Feb 6, 2003 | 01:46 PM
'94 Bad A Z28's Avatar
I have an A4 w/ the stock 3.23 gears... I don't shift into 3rd untill 70-75?! But I have an auto.
Dr.Mudge's Avatar
I have an M6 by the way, don't know what the original poster is using.
Old Feb 6, 2003 | 01:49 PM
CODY BEHNKE's Avatar
My Formula A4/2.73 shifts out of second at 96mph
Old Feb 6, 2003 | 05:57 PM
Grn96Z's Avatar
damn something def isnt right then, I have to shift into 4th at around 90 and im at around 6000rpm. What can be my problem??
Old Feb 6, 2003 | 06:27 PM
Grn96Z's Avatar
Anyone have any suggestions on this? I did blow my engine a few months ago and have since had a new one put it under warranty for free Could they have messed something up with the computer or something?? What do you guys think
Old Feb 6, 2003 | 06:28 PM
TMDZ28's Avatar
shift to 3rd at 96??? damnnnnn
Old Feb 6, 2003 | 06:44 PM
Grn96Z's Avatar
anyone know what mph I should be shifting 3-4, its a 6-speed by the way. The car is basically stock except exhaust and cai. WHy is the mph so low?
Old Feb 6, 2003 | 06:56 PM
LimitedEd1LE's Avatar
That sounds about right to me. You should shift into 4th at about 90-96mph. Thats when I shifted into 4th at the track.
Old Feb 6, 2003 | 07:06 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
silly gooses
thats why we have math
learn it, live it, love it
woops
didn't realize the doctor paid a visit already
Old Feb 6, 2003 | 07:22 PM
teke184's Avatar
according to the mph calculator on thirdgen.org:
assuming a 245-50-16 tire, 6000 rpm, 3.42 rear and a third gear of 1.43, the mph equal 93.5.
i'm not 100% positive on the third gear ratio...but i know that's close.
so you are pretty much right on. i know the first time i went to the track i tried running 3rd through the traps, bounced the rev limiter right at the end and i trapped 96mph...
Old Feb 6, 2003 | 07:26 PM
Dr.Mudge's Avatar
A couple things, the stock rev limiter is before 6k. With that in mind, the guages are not all that accurate, so if they seem off by a little bit dont worry about it.
Are you honestly hitting the limiter at a solid 90 MPH? Check the Fbody gears site, and punch in your tire numbers. If the tires are worn a bit then that will further explain a little bit of top end loss, since the diameter will be a little less than stock.
