Changing Spark Plug wires ?????
Old Feb 6, 2003 | 07:33 PM
scyzoryk's Avatar
I went to my mechanic shop and they said that it will cost me $80 to change the wires (+ I have to but a wires by my self). They said that it takes 2 hours, is that true?
ps. What is the best way to do that
Old Feb 6, 2003 | 07:44 PM
GhostZ's Avatar
DO NOT pay $80 plus the cost of wires to have them installed!!!
Take the time and do it yourself....it isn't hard, just follow the routing of your old wires and you'll be fine.
Tell them to go take a hike....if it were plugs you were changing with stock manifolds, I can see where it would take 2 hours (more) but not just wires.
Old Feb 6, 2003 | 08:04 PM
Bud M's Avatar
If they can do it in less time than that, I'll be impressed.
Old Feb 6, 2003 | 09:50 PM
sp528's Avatar
After I installed a bad set of wires on my T/A I had to go back and do just the wires. It took me about 2.5 hrs from start to finish (including the time to jack it up and all that). I also have headers on my car so it might be easier or harder to on your car if you have stock manifolds. My guess is it would be harder.
Adam
Old Feb 6, 2003 | 10:15 PM
Loadre's Avatar
Re: Changing Spark Plug wires ?????
If they're charging $80 then apparently they've never done plugs/wires on a LT1 camaro/firebird before Like it's been said, do it yourself, you'll save money, learn stuff, and make sure everything is right instead of having them f something up. It's really not that hard, just time consuming.
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
