couple of Ram-Air questions
Old May 6, 2003 | 03:45 PM
SilverBulletWS6's Avatar
i have a 96 ws-6 and want to know what fernco parts are needed to replace the
airbox to maf
and
maf to tb
also i have a holley powershot filter so can i shave the baffles down .....maybe not all the way but maybe some of it? just cocerned on rain....i did a search but didnt really find the answer i was lookin for
Old May 6, 2003 | 05:30 PM
Josh-'04 GTO's Avatar
The stock airbox to MAF connector I left stock as it is not a restriction. The MAF to TB is 3" diameter by 4" long. Throw it in some boiling water to loosen it up before trying to install it.
If your car is a daily driver, just try shaving about 1/2" off the bottom of the front baffle and maybe 1/4" off the top of the rear baffle. I took out the front baffle all together, but the first time I ran it through the car wash the MAF went crazy.
Old May 6, 2003 | 07:45 PM
well the piece from the airbox to the maf is all messed up so i need to replace it.....not an option...so would that be the 3" to 3" fernco......notice any real improvments without the baffle???s
also when i went to home depot...the fernco seemed so thick is it supposed to be real thick?
Old May 6, 2003 | 08:33 PM
97FormulaWS-6's Avatar
Well... it depends on what MAF you are running, but for a factory MAF the only replacement for the MAF to Airbox is the factory one.
The Fernco part is thick, probably 1/4" or 3/8" but it works quite well.
On my car you can see how it goes together on my website (Little red button on bottom of this post, pg 5). I'm running a Z06 MAF which had a larger inlet diameter so I have to run a cut-down Fernco coupler between it and the Airbox, but that's only due to the diameter diference between the Factory and Z06 MAFs.
I totally removed the Middle/Front baffle, and am only running the rear one. When I looked at how the airbox seals, I see no reason to remove much if any of the rear baffle, but I'm also running the seal glued to my hood, not glued to the airbox.
Any more questions?
Old May 6, 2003 | 09:36 PM
Yep... thus the boiling hot water trick! After the first time, the next time you take it off/put it back on, it will be much easier.
Old May 6, 2003 | 10:23 PM
NineSevenWS6's Avatar
That reminds me....I still have to do mine..
It is definatly thick...looks like it will take a bit of convincing... Should be fun.
Old May 6, 2003 | 11:15 PM
so from the airbox to the maf it has to be the stock replacement bellow? you cant just cut a certain lenght fernco?
so for the hood take out the front baffle?
Old May 6, 2003 | 11:19 PM
Barry 94Formula's Avatar
Boil it. Then take a butter knife and use it to guide the rubber onto the intake. That's what I did.
Old May 6, 2003 | 11:39 PM
kgkern01's Avatar
Don't mean to jump in the post here, but I was wondering something about the LT1 WS6 Ram-Air setup. Is it a problem driving in heavy rain in those? It looks like you have direct scoop-to-filter-to-intake on those and always wondered if there is any type of water drain on those to prevent sucking in the water. Have always wondered that.
Old May 7, 2003 | 12:00 AM
There is still somewhat of a maze for the air to travel through, and yes there are drains on either side...
Havent had a problem with mine yet.
Fastbird93's Avatar
That's why there's baffles in the hood portion of the intake. A lot of guys cut those baffles out (note to self--put that on project list) and don't have a problem.
Old May 7, 2003 | 12:07 AM
oh anyone got a part# for the black piece of rubber between the airbox to the maf.....mine is so messed up i cant see a #
Old May 7, 2003 | 12:56 AM
craigffb's Avatar
I'm actually using the one off my stock air box (I have an SLP hood and a GM air box). You might try and see if you can get it from someone who when with a CAI.
Old May 7, 2003 | 07:08 AM
With a factory MAF you HAVE to run the GM coupler, the MAF actually sits INSIDE the outlet of the airbox, that grommet/coupler is what seals it together.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jan 13, 2015 09:52 PM
ChrisFrez
Jan 4, 2015 08:43 AM
0toinsanein5.4sec
15
Jul 31, 2002 01:31 PM
