TB bypass- barbed connector from Pep Boys?
Old May 7, 2003 | 04:09 AM
bad1LEz's Avatar
Going to do the bypass this w/e. Went to Pep Boys and picked up a white barbed connector. It's plastic, but real hard. Is this OK to connect my hoses with? Won't melt will it? And I need one b/c my car is a '94.
Old May 7, 2003 | 04:33 AM
David96Z's Avatar
It should be ok, but I didn't use anything. i disconnected the hose on the drivers side TB and took the passenger hose off completely then just hooked up the drivers side hose to where the pass. side had been connected. No fittings needed just used the same hose clamp.
Old May 7, 2003 | 04:49 AM
GhostZ's Avatar
Same here.
Old May 7, 2003 | 05:25 AM
magius231's Avatar
thats what I did too.
Old May 7, 2003 | 06:09 AM
Mtrhds94Z's Avatar
95-7 don't need a hose barb.. 93-4 do..
I'd use brass but the plastic is probably OK.
Any hardware store has em or Home Depot, etc..
3/8" hose barb connector..
Old May 7, 2003 | 08:09 PM
Bud M's Avatar
I used a brass one. It was a buck and a half at Home Depot I wouldn't trust plastic under the heat and the force of the clamps. If it fails you'll be kicking yourself.
Old May 7, 2003 | 09:15 PM
zuluman13's Avatar
im doing the bypass also and the one on the passenger side i cant get off there is too much stuff in the way it took a while to get the clamp off but i did but its still a pia to get the hose off does anyone have anytricks
Old May 7, 2003 | 09:43 PM
Bud M's Avatar
Get a friend to help. One guy twists and pulls while the other pushes a small screwdriver between the hose and the fitting and pries them apart and sprays WD40 in the gap.
Old May 7, 2003 | 11:46 PM
Ditto.
Jeff1904
Jun 5, 2016 05:00 PM
football4life
Oct 4, 2015 07:48 AM
Double aught
Oct 2, 2015 11:29 PM
autoxr166
Sep 25, 2015 04:21 PM
NewsBot
Sep 15, 2015 11:53 AM
