PLEASE HURRY!!! - in the middle of TB BYPASS
Old May 6, 2003 | 03:24 PM
95patriotZ's Avatar
doing a TB BYPASS right now on my 95 Z and wanted to double check that the second hose you disconnect is the small (about 3-4" long 90 degree bent hose coming from a small metal pipe. Your help would be greatly appreciated!!!!!!!!!!!1
Old May 6, 2003 | 03:26 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: PLEASE HURRY!!! - in the middle of TB BYPASS
yup
its all the more easier if you look at it as "i am bypassing the throttle body" instead of disconnect wire that looks like a do-hickey...
all you are doing is connecting the tube that puts coolant into the TB to the tube that the coolant goes out of. basicaly cutting the TB out
Old May 6, 2003 | 04:52 PM
Mtrhds94Z's Avatar
This pic should help..
Compliments of shoebox' Tech Page..
http://csce.uark.edu/~jgbertr/rb/tb_bypass.jpg
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
