CC306 vs GM847 vs XE230/236
Old May 5, 2003 | 10:25 PM
Shon Herron's Avatar
Which one would you pick and why? To put on the car listed in sig.
Old May 5, 2003 | 11:31 PM
Dr.Mudge's Avatar
I'd run the GM847 probably, unfortunately I know nothing of torque converters though so I can't recommend something based on that.
Old May 6, 2003 | 03:04 PM
mastrdrver's Avatar
Going with the fact that you have a 3a, I would suggest the GM847, since it looks like your trying to go as fast as possible.
Old May 6, 2003 | 03:17 PM
xxsaint69x's Avatar
CC306
Old May 6, 2003 | 05:26 PM
Grease's Avatar
I'd definately go with the GM847. I've had some good luck with that cam
Old May 6, 2003 | 05:27 PM
atljar's Avatar
Crane 109841 .
Same as the 847. May be able to find it cheaper since its crane, maybe not.
Anyways, used it on 2 different LT1s and it screams.
Old May 6, 2003 | 10:36 PM
Dr.Mudge's Avatar
Yep, Crane/Blue does the GM cams, you can order from a dealership probably cheaper than most outlets charge for cams - but expect about $220 or so, so no huge savings in store.
Old May 6, 2003 | 10:55 PM
KCFormula's Avatar
What are the specs on the GM cam?
Old May 6, 2003 | 11:00 PM
atljar's Avatar
234/242 575/595 with 1.6 on a 112
Old May 6, 2003 | 11:42 PM
kgkern01's Avatar
What about for M6 car? I thought the CC306 was most powerful cam?
Old May 7, 2003 | 12:20 AM
atljar's Avatar
My dear child, how much you have to learn still
Old May 7, 2003 | 12:57 AM
speedmiser's Avatar
You may want to throw the CC XE 236/242 into the mix too.
Old May 7, 2003 | 01:36 AM
Dr.Mudge's Avatar
No, its just what everyone and thier grandma runs when they want something a little on the "big" size, there are cams with ALOT more "power" potential. CC306 is an OLD design, IMO its outdated, and the exaust duration is excessive.
It performs well, so there is no reason to be different for the sake of just being different, but there are better cams out there for most people.
Old May 7, 2003 | 02:51 AM
blksunshine's Avatar
excellent question, I have been wondering wich of these cams to go with myself. I am pretty sure the 230/236 peaks at 6500 and the rest you would have to rev higher. I just heard of this one from ultradyne 232-238 on a 110 LS and a 105 ICL custom cam.
Old May 7, 2003 | 09:49 AM
1994TransAm's Avatar
how will that crane 109841 work with a 355 LT1 w/ported heads?
i need to choose a new cam and i was going with 230/236.... but i like the sounds of that crane!!!! any idea what it would lay down...how's the driveability?
