Time for U-joints. Should I upgrade to an aluminum driveshaft?
Old May 6, 2003 | 07:03 PM
PGR's Avatar
PGR
My '94 M6 with 176k miles can use some new u-joints. Is it worth the trouble to replace them, or should I just order a new AL driveshaft? Does the new DS come loaded with new u-joints?
How about trying to pick up a used AL driveshaft from a salvage yard? What do they go for, and do all 4th gen AL driveshafts fit a '94 M6?
BTW, my stock steel driveshaft vibrates at above 80mph, and especially when I'm on and off the throttle.
Old May 6, 2003 | 07:29 PM
TonyJ's Avatar
Just an FYI. I was just at the Lingenfelter site and they're having a special on their 3-1/2" aluminum driveshafts. $299...
Old May 6, 2003 | 07:43 PM
Carlos01SS's Avatar
Pretty good price for an aluminum driveshaft.
Old May 6, 2003 | 08:10 PM
Joe Gee's Avatar
You can also use a DS off a third gen. Some of them came with alum drive shafts, I forgot the RPO code though. And I read somewhere GM replaced the stock ds on 3rd gens with aluminum ones under warranty if the owner complained about vibrations. So you could get lucky if you look around, some people just offer $25 and walk out with a 1LE aluminum driveshaft. You might want to do a search here or on thirdgen.org if you are interested.
Noenav
Mar 1, 2019 07:38 AM
*Emilia*
May 13, 2015 09:05 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jazsun
Dec 29, 2014 12:14 PM
