Rear Main Seal Install-help Needed
Old May 6, 2003 | 09:54 PM
chevycamaro1995's Avatar
What do I have to take out other than the tranny. My tranny is blown to pieces so I want to replace my rear main seal in my motor while im there. Isit true that i have to drop my oil pan among other problems?
Old May 6, 2003 | 10:01 PM
Does anyone have sugestions or stuff to watch out for?????
Old May 6, 2003 | 10:03 PM
PoorMan's Avatar
yes, u need to drop the pan. The back two left and right studs on back of the pan are screwed into the real main seal housing which needs to be taken off.
Jeff D.
Old May 6, 2003 | 10:04 PM
93TAWicked1's Avatar
Nope you do not have to drop the pan If the tranny is out it is a 2 minute job (of course you have to have the tranny out to do it)
Just pry the old one out with a screwdriver and then coat the rear main seal with oil and put it back in easy!
Old May 6, 2003 | 10:06 PM
Poor man I just changed my oil pan gasket today and am putting the main seal in later on today I replaced it a few months ago its fine but since I have it apart.... Anyways if you JUST replacing the main seal the pan does not have to be dropped if you replacen the housing gasket then yes you have to drop the pan.
In fact in the GM service manual it does not require to drop the pan so its not like I'm doing it half *** or anything!
Old May 6, 2003 | 10:30 PM
Same as what I have read. If you remove the housing, you have to drop the pan. It can be changed without removing the housing and therefore no dealings with the pan.
Old May 6, 2003 | 10:31 PM
Trust me after what I just went through you don't want to drop the pan and risk messing up the gasket if you dont' want to
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
