Oil pan plug stripped
Old May 6, 2003 | 05:31 PM
FLII ME's Avatar
Mechanic told me I have to replace the oil pan...
pan plug was stripped and for now it has a temporary plug in it.
Anyone know how much labor is involved?
Any link to help out? I am thinking of doing it myself, as I was told it would take anywhere from 4-6 hours.
thanks
Old May 6, 2003 | 05:36 PM
bunker's Avatar
Just shuw a plug in there, who cares, or just take the K-memeber out, hold engine with jackstand on tranny & hub, take K-memeber out just a bit, remove pan bolts/pan, should take around 4 hours to do the work, replace gasket while you're at it.
Old May 6, 2003 | 05:39 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
i would just retap the hole bigger, or helicoil it
Old May 6, 2003 | 06:14 PM
Mtrhds94Z's Avatar
They sell repair kits [its like an oversize plug and a tap..]
Use that, and then probe in the hole with a magnet etc, [to be sure it's clean of chips!]
Then flush the pan out good [by pouring light oil or a little kero thru it...]
I wouldn't change the pan..
I routinely use magnetic drain plugs.. but not sure you'll be able to get one in oversize..
Old May 6, 2003 | 06:18 PM
FLII ME's Avatar
thanks for all your help guys,
Old May 7, 2003 | 12:14 PM
fbird95's Avatar
How bad is it striped? If it has any part left to grab on it, you get it out with vice-grips to get it off and get a new plug. It shouldnt be torqued up to much, although it may be . Other wise you can just retap the hole. You said the plug. If you striped the pan itslef you can just retap it bigger and get a bigger plug like stated above
jer4251
Sep 21, 2020 09:42 PM
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Sandersen511
Jan 13, 2015 03:49 PM
Elcojoe
Nov 17, 2014 10:27 PM
