AS&M Headers question??
Old May 5, 2003 | 04:17 PM
97 Z-28's Avatar
Hey everyone, I am looking at the 94-95 style AS&M headers for my 97 Z-28. I was wanting to know if it will hook up to my emissions connection or not ? Is there any clearance problems with the steering shaft or does it fit great once installed? Also does the gaskets that come with the Headers good or should I get some felpro ones? Thanks for your time.
Old May 5, 2003 | 05:50 PM
Hawk's Avatar
I have that setup on a 96Z, i been thru it
buy felpro gaskets for the header/heads connection
you will need emissions check valve adapters, call www.thunderracing.com for them, tell them you have 94-95 style headers and u want the adapters to put them on a 97Z
They will not match up to your ypipe, buy the random tech dualcat ypipe setup or get a offroad pipe, you will also need a SPIPE to get it to mate to your catback, these are avaliable at mufflex and thunder i believe
Next, USE STAGE 8 locking header bolts
for the collecttors, AS&M's leak bad IMO, USE percy's aluminum gaskets(garanteed to never blow out, went thru like 4 felpro's until i used the aluminum's) they are avaliable at summit.
Install, and enjoy
Old May 6, 2003 | 06:01 AM
97 Z-28's Avatar
Cool thanks for te info. This is my plan for the y-pipe that comes with the headers. I already have the Random Technology cated y-pipe for the 96-97 LT1s. What I am planning on doing is once I get the headers installed and the y-pipe connected, I am goingto go to an exhaust shop for the last thing. On the back part of the 94-95 Style y-pipe, I am going to cut off the the y collector. Next I will take the my Random Tech y-pipe mark where to cut the 2, 2 1/2 inch pipes before the cats to mate it to the 94-95 pipe. Then have the 2 y- pipes welded together. I am basically just building the same combo that I could buy from www.ThunderRacing.com . With out spending $1200 bucks for it. So do you guys think it could work. From looking at both Y-Pipes, I think it could but I want your guys opinions. Thanks
Old May 6, 2003 | 06:50 AM
JeffK's Avatar
Hawk speaks the truth...I have not had one ounce of trouble with the aluminum collector gaskets since blowing out the others. Otherwise, it is a great setup in my opinion.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
