Signs of bad injectors???
Old May 5, 2003 | 04:35 PM
Red95Formula's Avatar
Question Signs of bad injectors???
I think I have some weak injectors or something on the right bank. I had some dyno tuning done this weekend to try and lean it out. But once the car goes closed loop the right bank goes to 108-118 and will not move until I start driving again. The left side at idle is 160. I just replaced all the plugs and installed a new o2 on the right. I am thinking that a few injectors are weak on the right side and spraying too much fuel. We bumped the fuel pressure up the other day before the dyno tune and after that is when it started running so rich. Any thoughts on the injectors???
Mods are
Stage II LT1 Heads
CC306
1.6 RR
52mm TB
Ported MAF
MSD6a
Everyother bolt on also
Chad
Old May 5, 2003 | 04:40 PM
turbo_Z's Avatar
more likely its caused by your TB and cam than the injectors. what brand TB do you have? some have more problems than others with what you are describing.
Old May 5, 2003 | 06:37 PM
I have a bbk 52mm tb. I wasnt doing this before i bumped the fuel pressure up the first time I was on the dyno. Thats why I was thinking the injectors were too weak for the fuel pressure. They are stock and running on 44-46 psi. I am going to swap them tomorrow and clean the tb and see if that helps.
Chad
ad356
Apr 11, 2015 08:49 AM
cmsmith
Mar 16, 2015 02:34 PM
Fatdog2
Feb 13, 2015 08:19 PM
Feb 13, 2015 07:37 AM
IgorT.455/406
Jun 4, 2003 03:32 AM
