Who makes DS safety loops for our cars
Old May 7, 2003 | 01:39 AM
IgorT.455/406's Avatar
Hey guys. I have a Jegs DS loop I bought for my '88 car, but I would also like to get one for my '94. Will the same loop fit and/or who makes a easy bolt on one that is not too expensive. Thanks guys.
Old May 7, 2003 | 01:49 AM
GhostZ's Avatar
If I remember right, BMR makes a torque arm with a driveshaft safety loop attached to it. If not, you may just want to check BMR and compare their prices with those of the Summit DS safety loop.
Old May 7, 2003 | 01:51 AM
GhostZ's Avatar
http://www.bmrfabrication.com/F-bodyChassis.htm
$100...but check the GP section, many vendors give some good discounts on BMR products.
Old May 7, 2003 | 01:57 AM
Wild1's Avatar
I've got the LG Motorsport loop... nothing special to write about and it comes with a price. I've also heard that Spohn has a good set up.
Old May 7, 2003 | 02:30 AM
norcalstreet's Avatar
I recommend forgetting the DS loop in favor of a torque arm with a loop built in. You can continue to use the stock g-load brace or remove it. If your car is lowered the BMR safety loop creates a clearance problems. I've found if you hit a bump hard enough it's possible to actually pull it out and ruin the threads.
Old May 7, 2003 | 06:36 AM
IDOXLR8's Avatar
Another option would be Spohn.
Old May 7, 2003 | 01:29 PM
Wild1's Avatar
That's one thing that can be said about the LG Motorsports loop, if you lower the car, there is plenty of clearance. But eventhough I have it, I feel it is too much money.
ChrisFrez
Dec 7, 2014 06:01 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
siguy
Nov 27, 2014 10:07 AM
USAirman93
Nov 24, 2014 03:37 PM
